Automation Hub User Guide
Automation CloudAutomation Cloud Public SectorAutomation Suite
Last updated Dec 18, 2024
Starting as an RPA Sponsor
After successfully logging in, you, as an RPA Sponsor, can check out the list of the and Components submitted within your tenant.
You are encouraged to Share your own ideas or components that will boost the company’s RPA assimilation as well as keep an eye on the tenant evolution through the Dashboards Overview module.
Within the Workspace Overview module, you can have a detailed view over:
