Automation Hub User Guide
Last updated Dec 19, 2025
Submit a Citizen Developer automation
If you are assigned as a Citizen Developer Self User or Citizen Developer Power User and have automated a manual, repetitive task, or process you are encouraged to share your automation project so that other members of your team can beneficiate from using it.
To start the process click the Submit idea button available on the top, right-hand side of the page.
As per your current permissions, you are now asked to select a Business Area for your automation. From the dropdown list, choose one that applies. Continue with a Category, Sub-Category, if the case. Based on the selection and according to your permissions, the system loads the list with available idea flows (e.g. Employee-driven idea, CoE-driven idea, Citizen Developer automation, Change request) that can be selected in Idea type.
Once you select the Citizen Developer automation option, the automation submission form is displayed. Carefully fill in all the requested information. Please check the Sharing an Automation page for details about the fields from the form.
Submit an Automation Flow
As soon as you submit an automation, the below flow is initiated:
  1. An Automation Profile is created for your automation. Check it to follow its evolution and updates.
  2. The automation undergoes several reviews. This depends on your assigned permission level. Check out the for more information.
Below you can find a graphic display of the Citizen Development automation flow:
  • Submit an Automation Flow
