studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-005 - Hardcoded Activity Properties
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Studio User Guide
Last updated Dec 12, 2025
You are automating a Java application or a web application and the corresponding extension (the extension for Java, Chrome, Microsoft Edge, Firefox) is not installed on the remote machine.
The error message indicates that you need to install/enable the associated UiPath Extension on the remote machine.
Install the required extension on the remote machine by using one of the following options:
- Run the
UiPathRemoteRuntime.msiinstaller, as described here in Installing the UiPath Remote Runtime. - Run the
SetupExtensions.exetool located in the installation folder of UiPath Remote Runtime (default%ProgramFiles(x86)\UiPath\RemoteRuntime), as described in SetupExtensions tool.
