studio
Studio user guide
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Check if ChromeNativeMessaging.exe is running
Verify that ChromeNativeMessaging.exe is running in Microsoft Edge to ensure communication between the UiPath Extension for Edge and Studio or Robot.
The ChromeNativeMessaging.exe enables communication between the UiPath Extension for Edge and the UiPath Studio/Robot.
Open Microsoft Edge.
Open Task Manager.
Check if the
ChromeNativeMessaging.exeprocess is running. -
If the process is not running:
