studio
Studio user guide
Extension for Edge
Install and configure the UiPath Extension for Edge to enable browser automation, including enterprise policy deployment and known version compatibility constraints.
Important:
UiPath Inc. and its affiliates, do not process, use, access, or store any customer data when using this product.
Microsoft Edge update to version 149​
The Microsoft Edge update to version 149 (started on June 2, 2026) introduced an upstream Chromium change that restricts the capabilities of extensions force-installed via enterprise policy when Developer Tools access is not explicitly allowed. For details, see this forum post.
To mitigate this issue, the following extension updates were released:
  1. On May 28, 2026, the Microsoft Edge Add-ons version of the UiPath extension installed via the Group Policy Online method (cdfjcmjmgdnojgaojdnefhjjpaijapci) was updated to version 26.10. This version is backward compatible and continues to work with older UiPath Studio and Robot versions.
  2. Starting with Studio 24.10.22 and Studio 25.10.12, the version of the Edge extension installed via the Group Policy Offline method (extension ID ndmegdjihnhfmljjoaiimbipfhodnbgf) was updated to version 26.10. Earlier 24.10 and 25.10 Studio versions install version 24.10 of the Edge extension.
This extension helps you create browser automations in Microsoft Edge. You can install this extension in multiple ways, as shown below:
Install from UiPath Studio​
Note:
The Edge v134 Sleeping Tabs feature affects the UiPath extensions 22.10, 23.4 and 23.10. This issue has been fixed in Microsoft Edge stable release 136.0.3240.92 (see Edge known issues). For more details and workarounds, refer to this forum thread.
  1. Open Studio.
  2. Navigate to Home > Tools > UiPath Extensions.
  3. Select Edge > Install. Choose one of the available methods from the drop-down:
    • Group Policy Offline
    • Group Policy Online
    • All Users
    • Current User
    • Native Host Only
  4. Open Edge and navigate to edge://extensions
  5. Enable the UiPath Browser Automation extension if needed.
Result​
The UiPath Extension for Edge is installed and active in Microsoft Edge.
Install from the Studio installer​
  1. Run the UiPathStudio.msi installer.
  2. Select an install mode, and then select Advanced Settings > Extensions > UiPath extension for Edge Chromium. If Edge is installed on your machine, the option is selected by default.
  3. Select Install. Studio setup continues while also installing the extension for Edge.
The UiPath Extension for Edge can also be installed from the command line of UiPathStudio.msi.
Result​
The UiPath Extension for Edge is installed.
Install from Group Policy​
You can also install the UiPath Extension for Edge by using Group Policies. This method silently installs the extension and enables it, without requiring user confirmation.
For both methods of Group Policy installation, the browser does not show the banner when the extension uses the debugger API.
Installation method recommendation​
We recommend using Group Policy Offline installation because the extension ID does not change when upgrading to newer versions. This method uses an extension that is signed by UiPath instead of the Edge Web Store. This means that after updating the version, there is no need to update the internal Group Policies (i.e. the ExtensionInstallForcelist policy) with a new extension ID.
Another advantage to re-using the same extension ID is that the settings configured for the extension (such as Allow InPrivate or Allow access to file URLs) are not reset after a version update.
Offline​
This installation method requires that the target machine is joined to a Microsoft Active Directory domain or Azure Active Directory.
It does not require access to the Edge Web Store so it can be used in controlled environments for machines that have restricted Internet access.
UiPathStudio.msi uses this installation method by default if its requirements are met.
Command line installation​
You can also use this installation method by running from an elevated command prompt:
&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-policy-offline /silent
If your organization uses Group Policies for browser extension management then the following changes are also required to be made in your organization's group policy definition:
  1. In the ExtensionInstallForcelist policy, add the value: ndmegdjihnhfmljjoaiimbipfhodnbgf;file:///C:/ProgramData/UiPath/UiPath.Common/EdgeExtension_SelfHosted/extension_manifest_edge.xml
  2. In the NativeMessagingAllowlist policy add the value: com.uipath.chromenativemsg_v2
    Note:
    You only need to set the NativeMessagingAllowlist policy value when the NativeMessagingBlockList policy is defined with the value of *.
  3. In the DeveloperToolsAvailabilityAllowlist policy, add the value: chrome-extension://ndmegdjihnhfmljjoaiimbipfhodnbgf
    In the DeveloperToolsAvailabilityBlocklist policy, add the value: https://uipath-devtools-blocklist-placeholder.invalid/
    Note:
    Instead of configuring DeveloperToolsAvailabilityAllowlist and DeveloperToolsAvailabilityBlocklist, you also have the option to set DeveloperToolsAvailability Group Policy to the value 1 (Allow usage of the Developer Tools) to enable the full extension functionality.
    However, we recommend the allowlist/blocklist policies option, as it enables you to specify only the UiPath extension ID, limiting the scope of the change to the required extension.
If you need to host the UiPath extension in your internal Web Store you can find the .crx file at this location:
C:\Program Files\UiPath\Studio\UiPath\BrowserExtension\uipath_extension_for_edge_self_hosted_mv3.crx
Important:
If these changes are not made after installation, the UiPath extension settings may be overwritten during periodic Group Policy updates.
Online​
This installation method requires that the target machine has access to the Edge Web Store (https://edge.microsoft.com/extensionwebstorebase/v1/crx and https://msedgeextensions.sf.tlu.dl.delivery.mp.microsoft.com).
UiPathStudio.msi uses this installation method if its requirements are met and the machine is not joined to a Microsoft Active Directory.
&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-chromium-policyglobal /silent
  1. In the ExtensionInstallForcelist policy, add the value: cdfjcmjmgdnojgaojdnefhjjpaijapci;https://edge.microsoft.com/extensionwebstorebase/v1/crx
  2. In the NativeMessagingAllowlist policy, add the value: com.uipath.chromenativemsg_v2
    Note:
  3. In the DeveloperToolsAvailabilityAllowlist policy, add the value: chrome-extension://cdfjcmjmgdnojgaojdnefhjjpaijapci
    Note:
Important:
Uninstalling​
The UiPath Extension for Edge can be uninstalled by running from an elevated command prompt:
&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-chromium-cleanup /silent
You can also uninstall by opening Studio, navigating to Tools > UiPath Extensions, and selecting Edge > Uninstall. The extension will be uninstalled with the same method used for the installation. This method is displayed in the disabled drop-down next to the Uninstall button.
Edge version requirements​
The UiPath Extension for Edge MV2 works with all existing Edge versions.
The UiPath Extension for Edge MV3 requires Edge version 98 or greater.
When using one of the installation methods described above, the browser version will be checked and the extension with the appropriate format (MV2 or MV3) will be automatically installed.
New extension features​
Support for IE Mode​
Starting with UiPathStudio.msi 2020.10 the UiPath Extension For Edge can be used to automate web pages running in Internet Explorer mode.
Web pages containing Java Applets, Silverlight and ActiveX controls can be automated in Internet Explorer mode.
Automating Edge apps​
Starting with UiPathStudio.msi 2022.4 the UiPath Extension for Edge can be used to automate Edge Apps.
Multiple Edge instances with multiple user profiles​
Starting with UiPath version 2023.10, the UiPath Extension for Edge supports automating multiple browser instances running with multiple user profiles at the same time.
For versions lower than 2023.10, the UiPath Extension for Edge did not support automating multiple browser instances running with multiple user profiles at the same time. As such, browser automation required you to close all active instances of Edge and restart the browser using a single user profile. Starting with version 2023.10 we can accommodate scenarios of multiple browser processes running under different browser profiles, such as the case when a specific application must run on a dedicated profile to isolate sensitive data from other applications.
Note:
Automating multiple browser profiles requires UiPath.UIAutomation.Activities v23.10 or newer and browser extension installed with UiPathStudio.msi v2023.10 or newer.
Opening the browser with a specific profile is now possible when using the Use Application/Browser activity. To specify a profile at browser start-up, you must append an argument to the browser command line. To do so, use the Arguments property in the Unified Application Target input section.
For Edge, the required argument is: --profile-directory="profile_path"
The profile_path is the relative path to the User data folder path specified for that Use Application/Browser activity. If the User data folder path isn't specified, then the profile path is relative to the default user data directory %LOCALAPPDATA%\Microsoft\Edge\User Data%. To find the profile path, navigate to edge://profile-internals/ and retrieve it from the Profile Path entry.
Troubleshooting​
Your system administrator might have configured Group Policies that prevent the Extension for Edge from working. To enable it, please follow the instructions from the Group Policies page.
For any other issues regarding the UiPath Extension for Edge, please view the detailed troubleshooting page.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
