studio
2025.10
Studio User Guide
Last updated Oct 30, 2025
The required UiPath extension is not installed on the remote machine
You are automating a Java application or a web application and the corresponding extension (the extension for Java, Chrome, Microsoft Edge, Firefox) is not installed on the remote machine.
Solution
The error message indicates that you need to install/enable the associated UiPath Extension on the remote machine.
Install the required extension on the remote machine by using one of the following options:
  • Run the UiPathRemoteRuntime.msi installer, as described here in Installing the UiPath Remote Runtime.
  • Run the SetupExtensions.exe tool located in the installation folder of UiPath Remote Runtime (default %ProgramFiles(x86)\UiPath\RemoteRuntime), as described in SetupExtensions tool.
  • Description
  • Solution
