studio
2022.4
Studio User Guide
Test Case Templates
Overview​
Use test case templates as base models for your test cases. For example, you can create a template with data variations to be reused on different tests. You can create test case templates for Test Automation projects, including other file type such as Global Exception Handler. For other projects (e.g., Process), you can create workflow templates.
Conditions​
  • The templates are specific to the project type and the language that is used to create it.
  • The templates cannot be converted to workflows, compiled, or published.
Extract File as Template​
  1. Open your workflow in Studio.
  2. In the Project panel, right-click a test case and select Extract as template.
You test case is now stored in Project > Templates. You can copy and paste or move it back to your testing folder.
Note:
You can create templates directly from the Templates folder for your test cases and workflows.
You can use the contextual menu within the Templates folder to perform various actions, such as comparing files.
  • Overview​
  • Conditions​
  • Extract File as Template​
  • Related Articles​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
