- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- Control Flow
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- Logging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Generating code
- Object Repository
- Extensions
- About extensions
- SetupExtensions tool
- Screen resolution settings
- Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Group Policies
- List of extensions for Edge
- Extension for Safari
- SAP Solution Manager plugin
- Excel Add-in
- Studio testing
- Troubleshooting
- About troubleshooting
- Assembly compilation errors
- Microsoft Office issues
Linking a Project to an Idea in Automation Hub
Link a Studio project to an existing Automation Hub idea by adding the idea URL in Studio project settings, enabling traceability between projects and ideas.
The integration between Studio and Automation Hub enables you to easily link Studio projects to ideas in Automation Hub:
- In Studio, you can link any project to an existing idea in Automation Hub by adding the idea URL in the project settings.
- In Automation Hub, for any idea that is in the Development phase and has the Not Started status, you can select to start development in Studio, which automatically opens your Studio instance and creates a new project that is linked to the idea.
As a prerequisite, Studio must be connected through interactive sign-in to an Orchestrator tenant where the Automation Hub service is enabled. You can add Automation Hub URL links from any Automation Cloud tenant in your organization.
Linking a Studio Project to an Existing Idea in Automation Hub
To link a Studio project to an idea in Automation Hub:
Open the project in Studio.
Select the Project panel > Project Settings
> General. -
In the Automation Hub URL box, enter the URL of the idea you want the project to be linked to, and then select OK. If the URL is valid, the project is linked to the idea.
Result
The Studio project is linked to the selected Automation Hub idea.
Managing the link to an Automation Hub idea
To change the idea a project is linked to, repeat the steps in the linking procedure and replace the existing Automation Hub URL with the URL of a different idea.
To navigate to the idea a project is linked to in Automation Hub, in the Project Settings window, click the
icon next to Automation Hub URL.
Starting a New Project From an Idea in Automation Hub
The option to start a Studio project from an idea in Automation Hub is available to users with the Start Development of projects assigned to CD Power Users permission, which can be assigned to any role in Automation Hub. After the permission is assigned, the user has the Start development in Studio option on ideas that are in the Development phase and have the Not Started status, regardless of their source or Development type. The status of the idea is changed from Development - Not started to Development - In Progress if the Start Development in Studio button is triggered.
To start a new Studio project from Automation Hub:
Open the Automation Profile of an idea that is in the Development phase and has the Not Started status.
In the Automation Profile, select More Actions on the lower-left side of the screen, and then select Start Development in Studio from the Actions menu.
Depending on whether Studio is installed on your machine, proceed as follows:
- If Studio v2021.10 or higher is installed, a browser pop-up prompts you to open Studio. If you accidentally close the browser pop-up, you can still open Studio by clicking the open the app link before moving to the next step
- If Studio is not installed or a version prior to 2021.10 is detected, download Studio using the options on the page. After you install Studio, click the open the app link to move to the next step.
A new Studio instance opens with the New Blank Process window for creating a new process. The idea title is added as the process name.
Configure the process details and select Create. The process is created and the idea URL is automatically added to the Automation Hub URL field in the project settings.
Result
The process is created in Studio and linked to the selected Automation Hub idea.
