studio-web
Studio Web user guide
- Getting started
- For administrators
- RPA workflow projects
- Creating an RPA workflow from an idea
- Creating a project
- How to start an RPA workflow
- Managing project files and folders
- Connecting RPA workflows to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- Local setup for RPA workflow and app projects
- App projects
- Agentic processes
- Maestro Case
- Maestro Flow
- About Maestro Flow
- Creating a Maestro Flow project
- Designing a Maestro Flow
- Publishing and deploying a Maestro Flow
- Agents
- Solutions
- API workflows
- Tests
Note:
Maestro Flow is in Preview.
To create a Flow project:
- Go to Studio Web.
- On the upper-right side of the page, select Create New.
- Select Maestro Flow. A new project opens with the Maestro Flow canvas displayed.
The Maestro Flow canvas opens with a default Manual Trigger node already placed.
Explorer
From the Explorer panel on the left, you can manage project files. Select the Add button to add a new file to your project.
