orchestrator
Orchestrator user guide
Managing custom roles
Custom role options and configuration settings available for managing user permissions in Orchestrator.
Apart from the default roles available in Orchestrator, you also have the possibility to create and manage custom roles. Adapting custom roles to the specific needs and permissions of users, help you to align more closely with your organization's needs.
Creating a role​
When creating a role, you can start from scratch and create a custom role, or you have the option to import a role.
Creating a Custom Role​
  1. Go to Tenant > Manage access and select the Roles tab.
  2. Select Add a new role and select if you want to add a new tenant or folder role.
    A form opens with all the permissions available for the type of role you selected.
  3. Make sure that the Add new option is selected at the top.
  4. In the Name field, Enter a representative name for the role, such as Action Center Superuser.
  5. Select the check boxes for the permissions you want to include in the new role:
    Figure 1. Selecting permissions for a new role
    The checkboxes for permissions that have no effect cannot be selected.
  6. Select Create.
The role is now available and you can add one or multiple users who need the set of permissions that this role provides by following the instructions below.
Importing a Role​
You can base a new role on a role you already have, even if the base role is in a different organization or tenant. If you export the base role, you can import it to any tenant and, if needed, customize it.
  2. If not already done, export the role that you want to use as a base.
    Note if the exported role is a tenant or a folder role.
  3. Select Add a new role and select if you want to add a new tenant or folder role.
    Make sure you choose the correct type, according to the type of the role you want to import.
  4. At the top of the page, select the Import option:
    Figure 2. Selecting the Import option
  5. Upload the CSV file obtained from exporting the base role.
    If the base role included permissions without effect that were selected, the message `Uploaded role contains unapplicable permissions.
Only applicable permissions are selected.` appears along the top. This indicates that, although selected in the base role, these permissions have been deselected following import because we no longer allow selecting these types of permissions.
The information of the imported role is displayed on the page. All permissions that the exported role included are selected.
Figure 3. Role permissions
  1. Optional:
    • edit the name to use for the new role being created and
    • select or deselect checkboxes to make changes to the permissions.
  2. When finished, Select Create.
  3. If the role includes elevated permissions (for example, Users - Create), a notification appears. Select OK to create the new role.
The new role is now available on the Roles page and you can assign it to accounts or groups as needed.
Editing a role​
  2. Select More Actionsdocs image at the right end of the row and select Edit.
    If the user whose role you want to edit has a robot that is currently busy, you are informed that any running jobs might fail, and are asked whether you want to proceed with saving your edits or cancel the operation.
    You cannot edit default roles, so there is no Edit option for these. If you need a custom version of a default role, select Duplicate & Customize instead (not available for mixed roles).
  3. Change the permissions as needed.
  4. Select Update.
Changes to roles apply immediately when a user logs in, or within one hour if the user is already logged in.
Removing a role​
You cannot remove any of the default roles, you can only remove custom roles.
Important:
Removing a role also removes it from any user that had it assigned. Users with no roles assigned cannot access any resource.
  2. Select More Actions docs image at the right end of the row and select Manage Users.
  3. Review the users who has this role assigned and make sure you reassign them to a different or similar role if needed before deleting the role.
  4. Select More Actions docs image at the right end of the row and select Remove.
Exporting a role​
If you want to recreate a particular role in a different organization or tenant, you can export the role as a CSV file and then import it in the target Orchestrator tenant.
To export a role as a CSV file:
  2. Select More Actionsdocs image at the right end of the row and select Export.
    Note:
    You cannot export mixed roles because we do not allow creating new mixed roles.
    A download begins for a CSV file which contains the role definition.
  3. Save the file locally.
You can now use this file to import the role into any Orchestrator tenant.
Important:
The CSV file is intended to be used strictly for importing back into Orchestrator in the form in which it was exported. Editing the file in any way can result in import errors.
If you need to make changes to the exported role, you have the option to do so during the import process.
  • Creating a role​
  • Creating a Custom Role​
  • Importing a Role​
  • Editing a role​
  • Removing a role​
  • Exporting a role​
