document-understanding
Implementar un paquete ML listo para usar
This page describes how to deploy an out-of-the-box Document Understanding ML Package. For demonstration purposes, we are going to use the Invoices ML Package as an example.
Crear un paquete ML Facturas​
For online installation, the Invoices model is already included in the Out of the box packages section. Go to ML Packages > Out of the box packages > UiPath Document Understanding > Invoices, and click Submit.
For offline installation, please upload the Invoices ML Package as a Zip file. To download the models, contact your Account Manager, CSM, or Support. You will receive a download link per package.
Elige el tipo de entrada Json y el lenguaje Python correspondiente.
Haz clic en Crear.
Implementar el paquete ML Facturas como una habilidad ML​
Go to the ML Skills tab from the left sidebar of AI Center and create a new ML Skill. This can take up to 30 minutes.
Once the ML Skill is created, double-click the ML Skill and go to Modify current deployment.
Activa el selector para hacer pública la habilidad ML. Es posible que tengas que esperar unos minutos y actualizar la página.
Once the ML Skill is ready, copy the URL, which is the endpoint of the Invoices ML Package for later use.
Congrats! You have successfully deployed the Invoices ML Model on AI Center.
¿Necesita ayuda? Soporte
