Process Mining user guide
- Before you begin
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Customizing process apps
- Publishing Dashboards
- App templates
- Additional resources
- Out-of-the-box Tags and Due dates
- Editing data transformations in a local environment
- Designing an event log
- Using .mvp Connectors
- Downloading DataBridgeAgent
- DataBridgeAgent
- System requirements
- Configuring DataBridgeAgent
- Adding a custom connector to DataBridgeAgent
- Using DataBridgeAgent with SAP Connector for Purchase-to-Pay Discovery Accelerator
- Using DataBridgeAgent with SAP Connector for Order-to-Cash Discovery Accelerator
- Extending the SAP Ariba extraction tool
- Performance characteristics
.mvp connector support in Process Mining on Automation Suite, enabling reuse of existing standalone connectors via DataBridgeAgent to load transformation output into process apps.
In Process Mining (Automation Suite), an existing Process Mining on-premises (standalone) connector (.mvp file) can be loaded using DataBridgeAgent. This enables you to reuse the existing Data transformations, and load the output data into a process app in Process Mining Automation Suite.
See Adding a custom connector to DataBridgeAgent for a detailed description on how to add a .mvp connector file created in Process Mining on-premises (standalone) to DataBridgeAgent.
