test-manager
- Démarrage
- Gestion de projet
- Documents
- Travailler avec l’analyse de l’impact des modifications
- Creating test sets
- Ajouter des cas de test à un ensemble de test
- Activation de la couverture des activités
- Configuration d'ensembles de tests pour des dossiers d'exécution spécifiques
- Cloner des ensembles de tests
- Exporter des ensembles de tests
- Linking Orchestrator test sets
- Appliquer des filtres et des vues
- Opérations et utilitaires de projet
- Paramètres de Test Manager
- Intégration de l'outil de gestion du cycle de vie des applications (ALM)
- Intégration de l'API
- Résolution des problèmes
Dernière mise à jour 9 sept. 2025
About the Automation Heatmap
linkThe Automation Heatmap gives you a tenant-level view of how your automation processes are tested. It helps you understand which processes are covered by test cases, how they perform in recent executions, and where testing gaps exist.
Each tile in the Automation Heatmap represents an Orchestrator process and shows the following:
- Process name: The name of the Orchestrator process.
- Folder: The Orchestrator folder name where this process is located.
- Version: The version of the Orchestrator NUPKG package linked to the process.
- Jobs: The number of jobs executed by the Orchestrator process.
- Error rate: ??
- Test cases: The number of Test Manager test cases linked to the Orchestrator process.
For details on linking Orchestrator processes to Test Manager test cases, visit .
- Test results: The latest execution result of the test cases linked to the Orchestrator process.
- A color-coded indicator for process quality: Passed, Failed, Not Tested, or Not Covered.
