ai-center
Guía del usuario de AI Center
Automation CloudAutomation SuiteStandalone
Última actualización 18 de dic. de 2024
2023.10.7
Release date: 18 December 2024
Corrección de errores
  • We fixed an issue that was causing ML Skills to fail after the Automation Suite cluster was restarted.
  • We fixed an issue where out of the box packages were occasionally not working properly.
  • We fixed an issue where an incorrect ai-proxy version was causing skill deployments to fail when using AI Center connected to an external standalone Orchestrator.
Problemas conocidos
There is a known issue in the current version where AI Center does not work in Automation Suite EKS environments with proxy enabled.
  • Corrección de errores
  • Problemas conocidos
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
© 2005-2024 UiPath. Todos los derechos reservados.
