  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
      • 2024.10.3+patch1
      • 2024.10.3+patch2
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
    • 2024.10.7
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated Dec 19, 2025
2024.10.3+patch2
Release date: December 15, 2025
About this patch
This release applies a patch to Automation Suite 2024.10.3. The patch addresses some issues in Action Center and Document Understanding. For more details, see the individual product release notes referenced in the Product versions section.
Important: This fix will also be included in all future releases starting with Automation Suite 2024.10.7. We recommend that you wait for Automation Suite 2024.10.7 to get this fix.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2024.10.3Automation Ops 2024.10.3AI Center 2024.10.3Action Center 2024.10.3-patch2
Task Mining 2024.10.3AI Computer Vision 2024.10.3Insights 2024.10.4Apps 2024.10.3
Process Mining 2024.10.3Document Understanding AI Center-based projects 2024.10.3-patch2Orchestrator 2024.10.5
  Test Manager 2024.10.3
  Data Service 2024.10.3
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.31.4+rke2r1
ArgoCDv2.14.4
gatekeeper3.18.2
rook1.16.1
ceph19.2.0
prometheus-pushgatewayv3.0.0
cert-managerv1.17.1
kube-logging/logging-operator5.2.0
kube-logging/config-reloaderv0.0.7
istio1.25.0
velero1.15.2
reloaderv2.0.0
Prometheusv3.2.1
Grafana11.5.2
redis-operatorv7.8.4-9
redis-clusterv7.8.4-95.focal
oauth2-proxyv7.8.1
  • About this patch
  • How to apply the patch
  • Deprecation timeline
  • Bundling details
  • Product versions
  • Internal third-party component versions
