Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
    • 2024.10.7
    • 2024.10.8
    • 2024.10.10
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
2024.10.4+patch1
2024.10.4 Patch 1 release notes for Automation Suite on EKS/AKS.
Release date: August 26, 2025
About this patch​
This release applies a patch to Automation Suite 2024.10.4. The patch addresses some issues in Integration Service, Studio Web, and Orchestrator. For more details, see the individual product release notes referenced in the Product versions section.
Important:
This fix will also be included in all future releases starting with Automation Suite 2024.10.5. We recommend that you wait for Automation Suite 2024.10.5 to get this fix.
How to apply the patch​
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2024.10.4+patch1.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
ProductVersionRelease notes
Action Center◆ Bundled: N/AN/A
AI Center◆ Bundled: N/AN/A
AI Computer Vision◆ Bundled: N/AN/A
Apps◆ Bundled: N/AN/A
Automation Hub◆ Bundled: N/AN/A
Automation Ops◆ Bundled: N/AN/A
Data Service◆ Bundled: N/AN/A
Document Understanding◆ Bundled: N/AN/A
Insights◆ Bundled: N/AN/A
Integration Service✅ New: 2024.10.4-patch1Integration Service release notes
Orchestrator✅ New: 2024.10.7Orchestrator release notes
Process Mining◆ Bundled: N/AN/A
Studio Web✅ New: 2024.10.4-patch1Studio Web release notes
Task Mining◆ Bundled: N/AN/A
Test Manager◆ Bundled: N/AN/A
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.25.2
ArgoCD3.0.0
Prometheus3.3.0
Grafana11.6.1
Fluentd and Fluent-bitlogging-operator: 5.3.0
fluent/fluent-bit:4.0.1
Gatekeeper3.19.1
Cert-Manager1.17.2
Velero9.1.0
  • About this patch​
  • How to apply the patch​
  • Deprecation timeline​
  • Bundling details​
  • Product versions​
  • Internal third-party component versions​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
