Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
    • 2024.10.7
    • 2024.10.8
    • 2024.10.9
    • 2024.10.10
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
2024.10.3+patch1
2024.10.3 Patch 1 release notes for Automation Suite on EKS/AKS.
Release date: May 16, 2025
About this patch​
This release applies a patch to Automation Suite 2024.10.3. The patch addresses some issues in Automation Hub. For more details, see the individual product release notes referenced in the Product versions section.
Important:
This fix will also be included in all future releases starting with Automation Suite 2024.10.4. We recommend that you wait for Automation Suite 2024.10.4 to get this fix.
How to apply the patch​
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2024.10.3+patch1Automation Ops 2024.10.3AI Center 2024.10.3Action Center 2024.10.3
Task Mining 2024.10.3AI Computer Vision 2024.10.3Insights 2024.10.4Apps 2024.10.3
Process Mining 2024.10.3Document Understanding AI Center-based projects 2024.10.3
Document Understanding modern projects 2024.10.3
Orchestrator 2024.10.5
Test Manager 2024.10.3
Data Service 2024.10.3
Studio Web 2024.10.3
Integration Service 2024.10.3
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.25.0
ArgoCD2.14.4
Prometheus3.2.1
Grafana11.5.2
Fluentd and Fluent-bitlogging-operator: 5.2.0
logging-operator-logging: 5.2.0
Gatekeeper3.18.2
Cert-Manager1.17.1
Velero8.5.0
  • About this patch​
  • How to apply the patch​
  • Deprecation timeline​
  • Bundling details​
  • Product versions​
  • Internal third-party component versions​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
