Automation Suite release notes
  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
    • 2024.10.7
    • 2024.10.8
    • 2024.10.9
    • 2024.10.10
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
2024.10.4
2024.10.4 release notes for Automation Suite on EKS/AKS.
Release date: June 26, 2025
Changes to the patching procedure​
The procedure for applying patches now includes an additional step that requires you to download and use the corresponding uipathctl patch version before proceeding with the patch.
For more details, refer to Applying a patch.
Deprecation of UiPath managed backup​
Starting with Automation Suite 2025.10, if you are using Automation Suite on AWS EKS or Azure AKS, you will need to leverage the AWS or Azure managed backup solution for backups. This allows you to unify your cloud backup strategy. The backup solution previously managed by UiPath will no longer be available.
Bug fixes​
  • We have fixed an issue causing the Automation Suite deployment on a shared EKS cluster to fail when using a namespace different from uipath. The network policy helm chart now correctly handles custom namespaces.
  • An issue was causing the Kubernetes upgrade to fail due to an incorrect configuration in Integration Service. The upgrade failure triggered the following error message: Cannot evict pod as it would violate the Pod's disruption budget. We have fixed the issue.
  • Log forwarding did not work in proxy setups because the proxy environment variables were not set in the logging pods. We have fixed the issue.
  • Licensing SQL connection errors occurred when the Data Source property specified both a named instance and a port. We have fixed the issue.
Known issues​
Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled​
Erratum - added July 2, 2026: An issue causes the prerequisite checks command to incorrectly fail when Document Understanding modern projects is enabled and AI Center is disabled.
To address the issue, refer to Troubleshooting.
This issue is fixed in Automation Suite 2024.10.9.
Custom platform database name not supported when installing Process Mining​
Erratum - added March 26, 2026: When Process Mining is enabled, using a custom platform database name causes the OMS backfill job to fail.
As a workaround, use AutomationSuite_Platform as the platform database name when installing Process Mining.
Studio Web deployment limitation​
Erratum - added March 26, 2026: Studio Web is not supported in Automation Suite shared cluster deployments.
Object Store prerequisite validation fails when using Azure Managed Identity​
Erratum - added March 26, 2026: When configuring Azure Blob Storage with a User Assigned Managed Identity, the Object Store prerequisite check incorrectly requires the Storage Account Contributor role. The check fails if the Managed Identity is assigned only the Storage Blob Data Contributor role.
To address the issue, assign the Storage Account Contributor role to the Managed Identity to allow the prerequisite validation to pass.
We fixed the issue in Automation Suite 2024.10.8.
FIPS 140-2 support limitations​
Erratum - added January 22, 2026: Insights and Integration Service are not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable these services.
For details, refer to Security and compliance.
Prerequisite checks fail when Process Mining is enabled​
Erratum - added December 19, 2025: An issue causes the prerequisite checks to fail when Process Mining is enabled. The issue occurs due to the checks still requiring cert-manager, although cert-manager is no longer needed for Process Mining starting with Automation Suite 2024.10.3.
The failure message is a false positive and can be safely ignored.
We fixed the issue in Automation Suite 2024.10.7.
Velero backup fails with FailedValidation error​
Erratum - added September 24, 2025: An issue prevents Velero scheduled backups from running successfully. A FailedValidation error message is displayed, indicating that no default backup location can be found. This issue occurs because the default-bs1 backup storage location is not marked as the default. As a result, Velero cannot identify a valid backup target, and scheduled backups fail.
To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2024.10.5.
Deprecation timeline​
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details​
Product versions​
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2024.10.4Automation Ops 2024.10.4AI Center 2024.10.4Action Center 2024.10.4
Task Mining 2024.10.4AI Computer Vision 2024.10.4Insights 2024.10.4Apps 2024.10.4
Process Mining 2024.10.4Document Understanding AI Center-based projects 2024.10.4
Document Understanding modern projects 2024.10.4
Orchestrator 2024.10.6
Test Manager 2024.10.4
Data Service 2024.10.4
Studio Web 2024.10.4
Integration Service 2024.10.4
Internal third-party component versions​
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
ComponentVersion
Istio1.25.2
ArgoCD3.0.0
Prometheus3.3.0
Grafana11.6.1
Fluentd and Fluent-bitlogging-operator: 5.3.0
fluent/fluent-bit:4.0.1
Gatekeeper3.19.1
Cert-Manager1.17.2
Velero9.1.0
Migration tool version​
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
