- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
Automation Suite release notes
Release date: April 28, 2025
Disaster Recovery – Active/Passive deployments
Erratum - added May 8, 2025: We are happy to announce that Disaster Recovery in Active/Passive configuration is now supported for Automation Suite on EKS.
Now you can configure Automation Suite in a way that can withstand the complete failure of nodes, entire data centers, or even regions.
Automation Suite deployments in Active/Passive mode support the following scenarios:
- Same-region deployment
- Cross-region deployment
For details, see Disaster Recovery – Active/Passive and Quick links.
Automation Suite Installer Wizard available in GA
We are excited to announce that the Automation Suite Installer Wizard, the new method for generating the Automation Suite input.json configuration file, is now generally available.
PostgreSQL for Process Mining Airflow database
For Process Mining on Automation Suite 2024.10.3, you can now choose to use PostgreSQL for the AutomationSuite_Airflow database. If you choose not to use PostgreSQL and keep using Microsoft SQLServer, Process Mining on Automation Suite 2024.10.3 will run with a legacy version of Airflow.
Refer to SQL Requirements for Process Mining for more information on how to set up a PostgreSQL AutomationSuite_Airflow metadatabase.
You are recommended to move to PostgreSQL for the Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Latest versions of Apache Airflow have various functionality, performance, and security fixes that older versions lack.
Removed Dapr dependency for Process Mining
Starting with Automation Suite 2024.10.3, Process Mining will no longer have a dependency on Dapr.
Task-Mining, however, will still continue to have a dependency on Dapr.
If you are installing Automation Suite where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will not be installed.
In case of an Automation Suite upgrade where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will be automatically uninstalled if it was installed by Automation Suite installer. If Dapr was user managed (installed by user), then Dapr should be uninstalled manually. For more details, refer to the Uninstalling Dapr section.
Additional custom CA certificate support
You can include any additional custom CA certificate by providing the additonal_ca_certs key with the external CA certificate path in the input.json file.
Enhanced telemetry
Enhanced Automation Suite with a high-level summarized usage telemetry feature, provided guidance on viewing the generated XML file, and added telemetry sharing with UiPath Support via the Customer Portal.
Istio HSTS enabled by default
To enhance security, Istio HSTS is now enabled by default.
uipathctl improvements
- You can now list all the available options for the included and excluded flags when running the prerequisite checks command. For more details about
--list-options, refer to the uipathctl reference guide. - For better eficiency, the diagnostic checks are no longer executed during the bundle creation process. Previously, a health check was performed by default during the support bundle creation, requiring the explicit use of the
--skip-diagnoseflag to bypass it. For more details on how to run the diagnostic checks, refer to the uipathctl reference guide.
Bug fixes
- Due to an incorrect version of
intsvcs/oauth-token-refreshconfigured at the services level, the OAuth token refresh job attempted to fetch a version that is not available in the UiPath offline registry. This led to issues during execution. This is now fixed.
Known issues
Custom platform database name not supported when installing Process Mining
Erratum - added March 26, 2026: When Process Mining is enabled, using a custom platform database name causes the OMS backfill job to fail.
As a workaround, use AutomationSuite_Platform as the platform database name when installing Process Mining.
Studio Web deployment limitation
Erratum - added March 26, 2026: Studio Web is not supported in Automation Suite shared cluster deployments.
Object Store prerequisite validation fails when using Azure Managed Identity
Erratum - added March 26, 2026: When configuring Azure Blob Storage with a User Assigned Managed Identity, the Object Store prerequisite check incorrectly requires the Storage Account Contributor role. The check fails if the Managed Identity is assigned only the Storage Blob Data Contributor role.
To address the issue, assign the Storage Account Contributor role to the Managed Identity to allow the prerequisite validation to pass.
We fixed the issue in Automation Suite 2024.10.8.
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights and Integration Service are not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable these services.
For details, refer to Security and compliance.
Prerequisite checks fail when Process Mining is enabled
Erratum - added December 19, 2025: An issue causes the prerequisite checks to fail when Process Mining is enabled. The issue occurs due to the checks still requiring cert-manager, although cert-manager is no longer needed for Process Mining starting with Automation Suite 2024.10.3.
The failure message is a false positive and can be safely ignored.
We fixed the issue in Automation Suite 2024.10.7.
Log streaming does not work in proxy setups
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2024.10.4.
Deployment issue on shared EKS clusters with custom namespace
Erratum - added June 26, 2025: An issue causes the Automation Suite deployment on a shared EKS cluster to fail if the target namespace is not uipath. This issue is due to the network policy incorrectly expecting the presence of a uipath namespace regardless of the chosen namespace.
To address the issue, you must manually create a uipath namespace before deploying Automation Suite.
We have fixed this issue in Automation Suite 2024.10.4.
Kubernetes upgrade failure
Erratum - added June 26, 2025: An issue causes the Kubernetes upgrade to fail due to an incorrect configuration in Integration Service. The upgrade failure triggers the following error message: Cannot evict pod as it would violate the Pod's disruption budget.
To address the issue, you must increase the replica count of intsvcs-periodic deployment using the following command:
kubectl scale deployment intsvcs-periodic --replicas=2 -n uipath
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Service disruptions due to automatic secret rotation
Erratum - added June 26, 2025: To address this issue, you can edit the input.json file to disable secret rotation in the platform configuration. This change will persist through Automation Suite upgrades and reinstalls.
Take the following steps:
Update the
platformsection in theinput.jsonfile as shown in the following example:"platform": { "enabled": true, "advanced_configuration": { "identity-service": { "secretRotation": { "enabled": false } } } }"platform": { "enabled": true, "advanced_configuration": { "identity-service": { "secretRotation": { "enabled": false } } } } -
After applying this configuration, you must reinstall your Automation Suite deployment to ensure the change takes effect:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.json
Erratum - added May 14, 2025: An issue causes service disruptions due to the automatic secret rotation, making services temporarily inaccessible.
To address this issue, take the following steps:
- Restart the affected service to restore its normal functionality.
- Navigate to the ArgoCD UI and from the platform applicatio, select Details > Parameters. Edit the values to add
"secretRotation: enabled: false"underidentity-service. You must take this step after each Automation Suite upgrade or reinstallation.
For AI Center, all skills must be stopped and started from AI Center UI.
Monitoring application stuck in Progressing state
After service installation, the monitoring application may remain in a Progressing state in ArgoCD.
To address this issue, you must manually sync the monitoring application with the Replace option:
- In the ArgoCD UI, go to the monitoring application in the
argocdnamespace. - Sync the application manually with the Replace option selected.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.25.0 |
| ArgoCD | 2.14.4 |
| Prometheus | 3.2.1 |
| Grafana | 11.5.2 |
| Fluentd and Fluent-bit | logging-operator: 5.2.0 logging-operator-logging: 5.2.0 |
| Gatekeeper | 3.18.2 |
| Cert-Manager | 1.17.1 |
| Velero | 8.5.0 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- Disaster Recovery – Active/Passive deployments
- Automation Suite Installer Wizard available in GA
- PostgreSQL for Process Mining Airflow database
- Removed Dapr dependency for Process Mining
- Additional custom CA certificate support
- Enhanced telemetry
- Istio HSTS enabled by default
- uipathctl improvements
- Bug fixes
- Known issues
- Custom platform database name not supported when installing Process Mining
- Studio Web deployment limitation
- Object Store prerequisite validation fails when using Azure Managed Identity
- FIPS 140-2 support limitations
- Prerequisite checks fail when Process Mining is enabled
- Log streaming does not work in proxy setups
- Deployment issue on shared EKS clusters with custom namespace
- Kubernetes upgrade failure
- Licensing SQL connection error
- Service disruptions due to automatic secret rotation
- Monitoring application stuck in Progressing state
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
