- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
About Automation Suite
Automation Suite is the self-hosted UiPath business platform that allows you to manage multiple UiPath products as one integrated solution. It provides a comprehensive set of tools and services for end-to-end automation, including process mining, document understanding, test management, and more. Automation Suite offers flexibility in deployment options, allowing you to install it on-premises or in the cloud. With Automation Suite, you can enable or disable specific products based on your needs.
Automation Suite includes the following:
- All server products, except for any new products shipping in Automation Cloud first.
- All shared suite capabilities that enable you to easily configure the integration with existing enterprise systems, such Microsoft Entra ID or SAML, across all products. We offer a common experience across the suite for the user, tenant, external applications, and license management.
- Common end-user portal.
This guide offers extensive instructions to cater to varying needs. For end users, it provides general documentation on how to use and navigate the Automation Suite portal. For administrators, the guide provides documentation on how to set up the organization security, authentication, licensing, and other configurations.
Product and service offering
The UiPath platform consists of various products designed to automate processes, enhance collaboration, and drive operational efficiency:
Action Center
UiPath Action Center is a tool designed to help you manage and resolve exceptions, errors, or decisions that require human intervention in your automation workflows. It provides a central interface for handling these exceptions, allowing human workers to review, make decisions, and take actions as needed to ensure the successful completion of automated processes.
Automation Suite Robots
UiPath Automation Suite Robots make it easy to run background automation without worrying about the necessary infrastructure. They provide you with complete freedom from provisioning, managing, maintaining, and scaling any underlying infrastructure. UiPath handles all the work behind the scenes so you do not have to deal with containers, virtual machines, or physical servers.
Visit the Automation Suite Robots documentation.
AI Center
UiPath AI Center is a service that allows you to deploy, manage, and continuously improve Machine Learning models and consume them within RPA workflows in Studio.
Visit the AI Center documentation.
AI Computer Vision
UiPath AI Computer Vision is a machine-learning based method used to visually identify all the UI elements on a computer screen and interact with them via UiPath Robots, simulating human interaction. It does not require or use the underlying properties of applications, but only the aspect and relationship of various screen elements.
Visit the AI Computer Vision documentation.
Apps
UiPath Apps is a low-code application development platform that enables you to build and share enterprise-grade custom applications that deliver engaging user experiences. Using Apps, you can quickly build custom business applications that connect to data in any underlying cloud or on-premises system using the power of automation.
Visit the Apps documentation.
Automation Ops
UiPath Automation Ops is a tool that enables you to manage and implement governance policies based on user profiles, and to manage the feeds available in your organization.
Automation Hub
UiPath Automation Hub is a collaborative process identification, automation pipeline management, and process repository tool. Its goal is to accelerate the adoption of RPA across your organization, by building an RPA Community of Interest.
Data Service
UiPath Data Service is a persistent data storage service that brings no-code data modeling and storage capabilities to your automation projects.
Document Understanding
UiPath Document Understanding uses pre-defined solutions to extract and categorize data from common document types. Utilizing pre-trained models, it can pull information from standard documents with ease.
Insights
UiPath Insights is a tool that serves as a platform for data modeling and analytics using a combination of available business metrics and operational insights into your automations and robot performance.
Integration Service
UiPath Integration Service is the component of the UiPath Platform that makes the automation of third-party applications much easier by standardizing authorization and authentication, helping you manage API connections, and also allowing faster integration into SaaS platforms. By using prebuilt APIs, the development of automation projects in UiPath Studio is more simple and more consistent, regardless of the third-party applications you are automating.
Integration Service is available only on Automation Suite on EKS/AKS.
Orchestrator
UiPath Orchestrator is a tool for streamlining the deployment, monitoring, and governance of your automation processes and robots, giving you flexibility to schedule and trigger these processes as per your requirements. It also supports the management of transactional data, often used in automating business processes.
Process Mining
UiPath Process Mining is a process mining solution that transforms data from your IT systems into visual interactive dashboards, allowing you to view existing value decreases, bottlenecks, and discrepancies, as well as understanding the root-causes and possible risks. It offers real-time, valuable insights to improve business processes over time.
Studio Web
UiPath Studio Web enables you to build and test cross-platform automations across online business apps and services. All you need to start using Studio Web is a web browser. You can access it from any operating system, it requires no installation, it has no IT dependencies, and it is always up to date.
Studio Web is available only on Automation Suite on EKS/AKS.
Task Mining
UiPath Task Mining offers insights into ongoing processes on your team's desktops, uncovering potential areas for automation and process improvement. This tool logs desktop data for each user action and uses AI to analyze it, thereby, giving you actionable insights for identifying automation ideas.
Task Mining is available only on Automation Suite deployments on EKS/AKS and Linux.
Test Manager
UiPath Test Manager is a test management tool for enterprise testing. It integrates into your ecosystem and adapts to your way of working, whether you use ServiceNow, SAP Solution Manager, Jira, Azure DevOps.
About Identity Server
UiPath® Identity Server is a service that offers centralized authentication and access control across UiPath products. Its purpose is to provide a coherent experience and parity of functionality for authentication and some aspects of authorization across all UiPath products and services. For Identity Server, these products and services are considered clients.
With the integration of Identity Server, its clients have a shared onboarding and user management experience. Behind the scenes, authentication is performed via Identity Server, which offers SSO experience and generates tokens to communicate with other products via APIs. Once a user signs in, Identity Server seamlessly performs the calls when accessing other products or services. The sign-out experience is similar - once a user signs out of one client, Identity Server performs the sign-out calls to all the other clients.
Identity Server also acts as a federation gateway, supporting external identity providers, thus shielding its client applications from details of how to connect to these external providers.
Identity Server offers Authentication as a Service, containing the centralized login logic and workflow for all its integrated applications, making it easier for services to integrate with each other over one standard protocol family: OAuth. It is built in .NET Core 3.1 on top of the IdentityServer4 open-source library, and supports the OpenID Connect and OAuth 2.0 frameworks.
