Automation Suite admin guide
Setting basic authentication at the organization level
Note:
This setting is only available if an external provider integration is enabled at the host or organization level.
When set at the organization level, the setting applies to all accounts in the organization.
For exceptions, basic authentication can also be set at the account level where you want this setting to apply differently.
To allow or restrict basic authentication for your organization:
  1. Log in to the organization-level Management portal at https://<server>/identity/management as an administrator.
  2. Go to Security Settings.
  3. Under Sign-in options for local users, turn on the Basic sign-in toggle to allow sign in using basic authentication:
  4. Select Save to apply your changes.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
