Automation Suite admin guide
Password complexity
Note:
Editing the Password complexity settings does not affect existing passwords.
The following table describes the password complexity you need when creating a password:
FieldDescription
Special charactersSelect to force users to include at least one special character in their password.
By default, this checkbox is not selected.
Lowercase charactersSelect to force users to include at least one lowercase character in their password.
By default, this checkbox is selected.
Uppercase charactersSelect to force users to include at least one uppercase character in their password.
DigitsSelect to force users to include at least one digit in their password.
Minimum password lengthSpecify the minimum number of characters a password should contain.
By default, it is 8. The length cannot be smaller than 1 or greater than 256 characters.
Days before password expirationSpecify the number of days for which the password is available. After this period, the password expires and needs to be changed.
The minimum accepted value is 0 (the password never expires), and the maximum is 1000 days.
Number of times a password can be reusedThe minimum accepted value is 0 (never allow reusing a password), while the maximum is 10.
Change password on the first loginIf set to Required, users that log in for the first time must change their password before being allowed to access Orchestrator.
If set to Not required, users can log in and continue to use the admin-defined password until it expires.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
