- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
About the host level
The host is the first level in the hierarchy. At this level, you can modify shared platform functionality like system administrator accounts, global authentication settings, global system email settings. You can also edit Orchestrator host settings from the host level. Only system administrators can access the host portal. Host settings apply across all the organizations.
Host Portal
The host portal is for system administrators to configure the Automation Suite instance.
The settings that you configure from this portal are inherited by all your organizations and some can be overwritten at the organization level.
For more information about how to use this portal, see the documentation under the Host Administration category of this guide.
Also see .
Orchestrator Host Portal
The UiPath Orchestrator host portal is available from within the Automation Suite host portal (see above). It allows system administrators to configure Orchestrator at the host level.
These settings are inherited by all your Orchestrator instances across the organization and some can be overwritten at the organization level.
For more information about how to use this portal, see the UiPath Orchestrator documentation.
Also see .
Organization admin portal
The Admin area at the organization level is where you can view and manage organization administrator accounts, organization authentication settings, organization system email settings, and other security settings. Only organization administrators (logged in to the organization) can access the organization Admin area.
To access the Admin area, navigate to the Login page at https://``AutomationSuiteURL``/ and log in to the organization with your organization administrator credentials. Once logged in, navigate to Admin from the left rail.
Signing in to the administration portals
Navigate to the Login page. The Login page opens.
For the Organization name, type
hostto access the host portals, or the name of your specific organization to access a specific organization portal.If a different organization is already set, select Change next to its name to specify a different organization name:
In the Username or email and Password fields, type your administrator credentials.
Select Log In and you are redirected to the appropriate portal.
