- Getting started
- Host administration
- Organizations
- Authentication and security
- Setting up the Azure AD integration
- Licensing
- Accounts and roles
- External applications
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
If your organization is using Azure Active Directory (Azure AD) or Office 365, you can connect your organization directly to your Azure AD tenant to see existing user accounts in your UiPath® environment.
The Azure AD integration allows you to continue leveraging local user model, if you want, while bootstrapping your organization with the additional benefits of using Azure AD.
If you have decided to use Azure AD for your organization, follow the instructions on this page to set up the integration.
To set up the Azure AD integration, you need:
- admin permissions in both Orchestrator and Azure AD (if you don't have admin permissions in Azure, collaborate with an Azure administrator to complete the setup process);
- an organization administrator UiPath account that uses the same email address as an Azure AD user; the Azure AD user does not require admin permissions in Azure;
- UiPath Studio and Assistant version 2020.10.3 or later;
- UiPath Studio and Assistant to use the recommended deployment.
- if you previously used local user accounts, make sure that all your Azure AD users have the email address in the Mail field; having the email address in the User Principle Name (UPN) field alone is not enough. The Azure AD integration links directory user accounts with the local user accounts if the email addresses match. This allows users to retain permissions when they transition from signing in with their local user account to the Azure AD directory user account.
appid query parameter in a dedicated URL, as described in Microsoft's access tokens documentation.
Your organization requires an app registration in your Azure AD tenant and some configuration so that it can view your AD members to establish account identity. The app registration details are also required to later connect your organization to your Azure AD tenant.
Permissions: You must be an administrator in Azure to perform the tasks in this section. The following Azure administrator roles have the required privileges: Global Administrator, Cloud Application Administrator, or Application Administrator.
There are two ways to set up your Azure tenant for the integration:
- Take the following steps to manually configure an app registration for the integration.
- Use the UiPath Azure AD scripts that we created for this task, which are available on GitHub: The
configAzureADconnection.ps1script performs all the actions described in this section and returns the app registration details. Then you can run thetestAzureADappRegistration.ps1script to make sure the app registration was successful.
To manually configure your Azure tenant, take the following steps in Azure Portal:
After the Azure setup is complete, you can prepare for the integration, activate it, and then clean up old accounts. The process is broken down in stages so that there is no disruption for your users.
Permissions: You must be an administrator in Orchestrator to perform the tasks in this section.
Clean up inactive users
When you connect Orchestrator to Azure AD by activating the integration, accounts with matching email addresses are linked so that the Azure AD account benefits from the same permissions as the matching UiPath account.
If your organization practices email recycling, meaning that an email address that was used in the past could be assigned to a new user in the future, this could lead to a risk of elevated access.
john.doe@example.com and this employee had a UiPath account where he was an organization administrator, but has since left the company and the
email address was deactivated, but the user was not removed.
john.doe@example.com email address. In such a case, John Doe inherits organization administrator privileges.
To prevent such situations, make sure you remove all users who are no longer active from Orchestrator before proceeding to the next step. If inactive email addresses are not reused in your organization, you can skip this step.
Activate the Azure AD integration
Before you begin
- Make sure that the Azure configuration is complete.
- Obtain the Directory (tenant) ID,Application (client) ID, and Client Secret values for the Automation Cloud app registration in Azure from your Azure administrator.
To activate the Azure AD integration, do the following in Automation Cloud:
Now you can work with the users and groups in the linked tenant's Azure AD. You can find Azure AD users and groups using search, for example to add a user to an Automation Cloud group. Also see the below FAQs for more information about what changes after the integration is active.
Test the Azure AD integration
To check that the integration is running from Orchestrator, sign in as an organization administrator with an Azure AD account and try to search for Azure AD users and groups on any page that has this functionality, such as the Edit Group panel in the Management portal (Admin > Accounts and Groups > Groups > Edit).
If you can search for users and groups that originate in Azure AD, it means the integration is running. You can tell the type of user or group by its icon.
If you encounter an error while trying to search for users, as shown in the example below, this indicates that there is something wrong with the configuration in Azure. Reach out to your Azure administrator and ask them to check that Azure is set up as described in Configuring Azure for the Integration above on this page.
Tip: Ask your Azure administrator to confirm that they selected the Grant admin consent check box during Azure configuration. This is a common cause why the integration fails.
After the integration is active, we recommend that you follow the instructions in this section to ensure that user creation an group assignations are handed off to Azure AD. This way you can build on top of your existing identity and access management infrastructure for easier governance and access management control over the resources of your Orchestrator organization.
Configure groups for permissions and robots (optional)
You can do this to ensure that the Azure administrator can also onboard new users with the same permissions and robot configuration for Orchestrator and other services that you had set up prior to the integration. They can do this by adding any new users to an Azure AD group if the group has the required roles already assigned in Orchestrator.
You can map your existing user groups from Orchestrator to new or existing groups in Azure AD. You can do this in several ways, depending on how you use groups in Azure AD:
- If users with the same roles in Orchestrator are already in the same groups in Azure AD, the organization administrator can add these Azure AD groups to the Orchestrator user groups that these users were in. This ensures that users keep the same permissions and robot setup.
- Otherwise, the Azure administrator can create new groups in Azure AD to match the ones in Orchestrator and add the same users that are in the Orchestrator user groups. Then the organization administrator can add the new Azure AD groups to the existing user groups to ensure the same users have the same roles.
Ensure to verify any roles specifically assigned to users, in all instances. If feasible, remove these direct role assignments, and add these users into groups already assigned with these roles.
For example, let's say the Administrators group in Orchestrator includes the users Anna, Tom, and John. These same users are also in a group in Azure AD called admins. The organization administrator can add the admins Azure group to the Administrators group in Orchestrator. This way, Anna, Tom, and John, as members of the admins Azure AD group, all benefit from the roles of the Administrators group in Orchestrator.
Because admins is now part of the Administrators group, when you need to onboard a new administrator, the Azure administrator can add the new user to the admins group in Azure, thus granting them administration permissions in Orchestrator without having to make any changes in Orchestrator.
Changes to Azure AD group assignments apply in Orchestrator when the user logs in with their Azure AD account, or if already logged in, within an hour.
Migrate existing users
Initial sign in: For the permissions assigned to Azure AD users and groups to apply, users must sign in at least one time. We recommend that, after the integration is running, you communicate to all your users to sign out of their UiPath account and sign in again with their Azure AD account. They can sign in with their Azure Ad account by:
- navigating to the organization-specific URL, in which case the sign in type is already selected;
by selecting Enterprise SSO on the main login page.
Note: Make sure you provide your organization-specific URL for Orchestrator to all your users. Only organization administrators can see this information in Orchestrator.
Migrated users benefit from the union of the permissions that were directly assigned to them and the ones from their Azure AD groups.
Configuring Studio and Assistant for users: To set up these products to connect with Azure AD accounts:
- In Assistant, open Preferences and select the Orchestrator Connection tab.
- Click Sign Out.
- For the connection type, select Service URL.
In the Service URL field, add the organization-specific URL, for example
https://orchestrator.mydomain.local/. - Sign back in with the Azure AD account.
Discontinue use of local accounts (optional)
Although optional, we recommend that you do this to maximize the core compliance and efficiency benefits of the complete integration between Orchestrator and Azure AD.
After all users have been migrated, you can remove the users which are based on personal local accounts from the Users tab, so that your users won't be able to sign in using their UiPath accounts anymore. You can find these accounts based on their icon.
Only remove non-administrator accounts. It is recommended to retain at least one organization administrator local account to be able to change authentication settings in the future.
You can also clean up individual permissions in the UiPath services, such as the Orchestrator service, and remove individual users from Orchestrator groups so that permissions rely exclusively on Azure AD group membership.
Here are a few useful pointers for advanced features you can leverage now that you have the Azure AD integration set up.
Restrict access to Orchestrator
Because the integration with Azure AD is performed at the level of the Azure tenant, by default all Azure AD users can access the Orchestrator organization. The first time an Azure AD user signs in to Orchestrator, they are automatically included in the Orchestrator group Everyone, which grants them the User organization-level role .
If you want to only allow certain users to access your Orchestrator organization, you can activate user assignment for the Orchestrator app registration in Azure. This way, users need to be explicitly assigned to the app (Orchestrator) to be able to access it. For instructions, see this article in the Azure AD documentation.
Restrict access to trusted networks or devices
If you want to only allow your users to access Orchestrator from a trusted network or a trusted device, you can use the Azure AD Conditional Access feature.
Governance for Orchestrator groups in Azure AD
If you have created groups in Azure AD for easy Orchestrator onboarding directly from Azure AD, as described above in the section Configure groups for permissions and robots, you can use the advanced security options of Privileged Identity Management (PIM) for these groups to govern access requests for Orchestrator groups.
If you have created groups in Azure AD for easy Orchestrator onboarding directly from Azure AD, as described above in the section Configure groups for permissions and robots , you can use the advanced security options of Privileged Identity Management (PIM) for these groups to govern access requests for Orchestrator groups.
- Overview
- Prerequisites
- Configuring Azure for the integration
- Deploying the integration to Orchestrator
- Clean up inactive users
- Activate the Azure AD integration
- Test the Azure AD integration
- Completing the transition to Azure AD
- Configure groups for permissions and robots (optional)
- Migrate existing users
- Discontinue use of local accounts (optional)
- Advanced features
- Restrict access to Orchestrator
- Restrict access to trusted networks or devices
- Governance for Orchestrator groups in Azure AD
