Automation Hub User Guide
Automation CloudAutomation Cloud Public SectorAutomation Suite
Last updated Aug 14, 2024
2023.4.0
Release date: 26 April 2023
What's Included in the Build?
  • UiPath Automation Hub and UiPath Insights integration is now available. This integration allows you to:
    • Get started quickly with a set of pre-built dashboards, ready to be customized as you see fit.
    • Keep stakeholders and sponsors informed on your automation program performance with consistent and schedulable reports.
    • Track your automation opportunities pipeline and take action quickly.
    • Encourage the growth of the automation program by understanding who and where employees are contributing.
    • Access to a set of views around the Reusable Components managed in Automation Hub. They're available in the Automation Ideas Explore, and they focus on the main details of the reusable components, the categories and applications referenced in the component profile, the versions, as well as information about the author, the curator, and the updater of the component.
  • A new History tab is available in each automation idea profile. This shows who, when, and what changes were made during the lifecycle of the idea. Only changes made to automation ideas starting with this release are visible in the History tab.
  • Admin Console > Platform Setup > Cost Setup > One Time Costs > Edit mode: Guatemala is now added to the Country list and GT as an abbreviation.
  • Admin Console > Platform Setup > Customize assessments: Outdated assessment versions can be deleted and not shown in the version history list. The assessment needs to be archived before it can be deleted.
To learn more about this integration check out the Automation Hub - Insights overview page.
  • What's Included in the Build?
