OpenShift 上的 Automation Suite 安装指南
上次更新日期 2025年11月6日
运行状况端点
要有效监控 Automation Suite 服务的运行状况,您可以使用本节中提供的运行状况端点。这些端点使您可以快速验证服务是否正常运行。
下表列出了 Automation Suite 产品和服务及其各自的运行状况端点。
服务运行状况端点
平台
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/buppoxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
AI Center
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
Apps
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Automation Hub
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Data Service
  • https://<automation-suite-fqdn>/dataservice_/api/healthcheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Insights
  • https://<automation-suite-fqdn>/insights_/health
通知服务
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
  • https://<automation-suite-fqdn>/orchestrator_/api/health
机器人管
  • https://<automation-suite-fqdn>/robotube_/healthz
Test Manager
  • https://<automation-suite-fqdn>/testmanager_/api/health/list
检查服务运行状况
要检查特定服务的运行状况,请将请求发送到其相应的端点,如以下示例所示。
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/healthcurl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
HTTP 状态代码 200 的成功响应表示服务运行良好。
  • 检查服务运行状况
此页面有帮助吗?
获取您需要的帮助
了解 RPA - 自动化课程
UiPath Community 论坛
信任与安全
© 2005-2025 UiPath。保留所有权利。
