test-manager
Test Manager user guide
Última actualización 11 de nov. de 2025
Test Manager Connect
Test Manager Connect offered by Planview® allows seamless integration between Test Manager and a multitude of Application Lifecycle Management (ALM) tools, through the Planview® Hub. Here are some benefits of using Test Manager Connect in Planview® Hub:
  • Synchronize testing artifacts between Test Manager and your desired ALM tool.
  • Updates made in Test Manager reflect in the tool you synchronized with.
  • Keep traceability of tests and requirements across various systems.
    For more information, visit the Test Manager Connect guide from the Planview Hub documentation.
Licensing
Test Manager Connect licenses, provided by Planview, come bundled with your Test Manager platform license. Visit Licensing Test Manager, and go to the Platform license section for more information about this license type.
You can download the on-premises version of Test Manager Connect from the UiPath Customer Portal. An on-premises license key comes with your Test Manager platform license.
Integrated ALM tools and Synchronization matrix
This table provides an overview of the most common integrations between Test Manager and various ALM tools through Planview Hub. Each integration has its corresponding synchronization matrix, outlining the specific synchronization capabilities for each type of testing object.
Important: The following synchronization matrix merely provides an overview. The final scope of an integration is documented in detail within the Planview documentation. Visit the UiPath Customer Portal from the Planview website, and navigate to the Product Documentation section for more information.
Defect creation in Test Manager is intentionally designed to be unidirectional. However, for existing artifacts, there is limited support available for bi-directional synchronization.
Legend
  • <-> - The synchronization is bidirectional.
  • -> - The synchronization is outbound, from Test Manager to the ALM tool.
  • ❌ - Synchronization not supported.
IntegrationRequirementsDefectsTest CasesTest steps (manual)Test SetsTest ResultsAssertionsDocumentation
Microsoft Azure DevOps<->-><->docs image<->->docs imageMicrosoft Azure DevOps documentation
Broadcom Rally<->->docs imagedocs imagedocs imagedocs imagedocs imageBroadcom Rally documentation
Atlassian Jira Cloud<->->docs imagedocs imagedocs imagedocs imagedocs imageAtlassian Jira Cloud documentation
Atlassian Jira Data Center<->->docs imagedocs imagedocs imagedocs imagedocs imageAtlassian Jira Data Center documentation
MicroFocus ALM<->-><->docs image<->->docs imageMicrofocus ALM documentation
MicroFocus ALM Octane<->-><->docs image<->->docs imageMicroFocus ALM Octane documentation
Mozilla Bugzilladocs image->docs imagedocs imagedocs imagedocs imagedocs imageMozilla Bugzilla documentation
Polarion ALM<->-><->docs imagedocs imagedocs imagedocs imagePolarion ALM documentation
ServiceNowNANANAdocs imageNANAdocs imageConsidering the versatile nature of ServiceNow, a wide range of artifacts can be synchronized. For specific scenarios, please consult the documentation for further clarification.
SmartBear QA Complete<->-><->docs imagedocs imagedocs imagedocs imageSmartBear QA Complete documentation
TestRaildocs imagedocs image<->docs image<->docs imagedocs imageTestRail documentation
Tricentis qTest<->->docs imagedocs imagedocs imagedocs imagedocs imageTricentis qTest documentation
Tricentis Tosca<->docs image<->docs image<->->docs imageTricentis Tosca documentation
Xray for Jira1docs imagedocs image<-><-><->-> ->Xray for Jira documentation
Zephyr Scale (TM4J)docs imagedocs imagedocs imagedocs imagedocs imagedocs imagedocs imageNA
Zephyr Essential (Squad)
Note: Available only through the Atlassian Jira connector.
docs imagedocs image<-><-><->->->Zephyr Squad connector documentation
1 - The XRay for Jira integration comes with certain limitations. These limitations are detailed in the Planview documentation. Visit the UiPath Customer Portal from the Planview website, and navigate to the Product Documentation section for more information.
Installers
Visit Customer Portal to download the Test Manager Connect installer.
Prerequisites
Before using Test Manager Connect in Planview Hub, you need to make the following configuration settings:
  • Create a new user account within your external tool, that should be used only for the integration with Tasktop Hub. Offer the needed permissions to artifacts inside your repository, such as Create, Read, Update, Delete (CRUD) permissions, or other permissions.
  • Add an external application inside your UiPath® Admin portal. The generated Client ID and Client Secret are used for connecting your Test Manager instance to Planview Hub.
  • Enable the following Application scopes in Test Manager, according to your use case:
ScopeDescription
TM.Projects.ReadProjects read access
TM.RequirementsRequirements read and write access
TM.ObjectLabelsObjectLabels read and write access
TM.AttachmentsAttachments read and write access
TM.Users.ReadUsers read access in Test Manager
TM.TestCasesTestCases read and write access
TM.TestExecutionsTestExecutions read and write access
TM.CustomFieldDefinitions.ReadCustomFieldDefinitions read access
TM.CustomFieldValuesCustomFieldValues read and write access
TM.TestSetsTestSets read and write access
TM.DefectsDefects read and write access
Follow the steps under the Connector Setup Details section.
Functional limitations
Defect synchronization is not available.
Additional resources
Learn how to integrate your Test Manager with your desired ALM tools, by checking out the following resources from the Planview Hub documentation:
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
