action-center
Guía del usuario de Action Center
Agregar comentario de tarea
Actividad AñadirComentarioDeTarea que añade un comentario a una tarea de Action Center por su ID de tarea.
UiPath.Persistence.Activities.FormTask.AddTaskComment
Descripción​
Indica al robot que agregue un comentario en una acción existente, indicada por su ID.
Compatibilidad de proyectos​
Windows - Heredado | Windows | Multiplataforma
Importante:
The Add Task Comment activity is available starting with v1.3.0 of the Uipath.Persistence.Activities package.
Windows, Windows: configuración heredada​
Panel del Diseñador​
  • TaskId(Int32) - The unique identifier of the existing Action.
  • Comment (String) - Write the comment for the Action. The comment is displayed in the Action summary and Comments panels.
Panel de propiedades​
Común​
  • ContinueOnError (Boolean) - Specify if the automation should continue even when the activity throws an error. The default value is False. As a result, if the field is blank and an error is thrown, the execution of the workflow stops. If the value is set to True, the execution of the project continues regardless of any error.
Nota:
If this activity is included in Try Catch and the value of the ContinueOnError property is True, no error is caught when the project is executed.
  • DisplayName(String) - The display name of the activity.
  • TimeoutMS (Int32) - Specify the amount of time (in milliseconds) to wait for the activity to run before an error is thrown. The default value is 30000 milliseconds (30 seconds).
Entrada​
  • Orchestrator Folder Path (String) - The path to the Orchestrator Folder you want to use with this activity. If left empty, the current Orchestrator folder is used. This field supports strings and String variables only.
Nota: si el usuario que realiza esta acción no tiene los permisos necesarios para la carpeta de destino, la adición de comentarios falla y arroja un error crítico. Consulta más información sobre los permisos de carpeta.
  • TaskId(Int32)—The unique identifier of the existing Action.
Advertencia: asegúrate de estar en la misma carpeta de Orchestrator que el proceso que generó la acción.
Otros​
  • Privado : si se selecciona, los valores de variables y argumentos ya no se registran en el nivel Detallado.
Configuración multiplataforma​
Opciones avanzadas​
Común​
Nota:
Entrada​
