- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
My notifications
Learn how to manage your personal notification preferences from the Notifications settings page in Automation Suite.
You can manage your notifications using the My Notification view on the Notifications settings page. You access the Notifications settings page through the Notification settings
icon on the Notifications panel or the Preferences menu option from your user account menu. Visit Notification settings to learn more.
The following section describes how to view and manage your notifications in the Notifications panel and the Notifications settings, and the notification events you can subscribe to.
Viewing and accessing notifications
You can access notifications through the Notifications panel only.
To access the Notifications panel, go to the top navigation bar and select the bell
icon. The Notifications panel displays notifications ordered by date, in descending order. The Notifications panel displays notifications from newest to oldest.
To access a specific notification, select the desired notification frame.
Filtering notifications
While you're in the Notifications panel, you can further filter the notifications, so you can view certain notifications first. To filter the notifications that you receive in the Notifications panel:
- Open the Notifications panel.
- Select the Service dropdown and then select the service for which you want to view notifications.
- Select the Severity dropdown and then select the severity of the notifications that you want to view.
Viewing and accessing email notifications
When an event that you are subscribed to takes place, an email notification is generated and sent to the email address that you used to create your account. To access the email notifications, check out the inbox of the email address where you know the notifications will be sent.
You can get the following information from the email:
- Read general information about the event that took place.
- Navigate to the corresponding service and tenant where the event took place.
Displaying only unread notifications
To display unread notifications, select the Unread only checkbox in the Notifications panel.
Marking all notifications as read
To mark all notifications as read:
- In the Notifications panel, select More Action on All Notifications at the bottom of the Notifications panel and then select Mark all as read.
Clearing all notifications
To clear all notifications from the Notifications panel:
- In the Notifications panel, select More Action on All Notifications at the bottom of the Notifications panel and then select Clear all.
Deleting notifications
You can delete notifications individually. To delete a notification:
- Go to a notification from the Notifications panel and select Action on Notification
. - Select Delete.
Selecting Delete permanently deletes a notification.
Subscribing to events
You can subscribe to certain events to receive notifications about them. Subscribe to events in the Notifications settings page.
The Automation Suite column is visible for services with in-app notifications enabled. The Email column is visible for services with email notifications enabled.
Subscribing to an event
Go to the Notifications settings page.
Go to a service tab and then go to the Automation Suite or Email column.
Select the checkbox that is inline with the event that you want to subscribe to.
If you want to receive both in-app and email notifications on an event, then select both checkboxes under Automation Suite and Email column.
Subscribing to all events
- Go to the Notifications settings page.
- Go to a service tab and then go to the Automation Suite or Email column.
- Select the Automation Suite or Email checkbox to subscribe to notifications on all events.
Unsubscribing from events
To stop receiving notifications, you can unsubscribe from certain events. You can unsubscribe from events from the Notifications panel or from the Notifications settings page.
Unsubscribing from the Notifications panel
- Access the Notifications panel.
- Go to a notification and select the Action on Notification
menu. - Select Unsubscribe from <event>.
Unsubscribing from the Notification settings page
Go to the Notification settings page.
Go to a service tab and then go to the Automation Suite column.
Deselect the checkbox that is inline with the event that you want to unsubscribe from.
If you want to unsubscribe from both in-app and email notifications for an event, then deselect both checkboxes under Automation Suite and Email.
Unsubscribing from all events
- Deselect the Automation Suite or Email checkbox to unsubscribe from notifications about all events.
Warning:
Unsubscribing from all the events of a service, via both Automation Suite and Email, generates the following warning: "You're not subscribed to receive any notifications from this service."
The Restore default subscriptions option restores the default subscriptions for notifications received both on Automation Suite and Email.
- Viewing and accessing notifications
- Filtering notifications
- Viewing and accessing email notifications
- Displaying only unread notifications
- Marking all notifications as read
- Clearing all notifications
- Deleting notifications
- Subscribing to events
- Subscribing to an event
- Subscribing to all events
- Unsubscribing from events
- Unsubscribing from the Notifications panel
- Unsubscribing from the Notification settings page
- Unsubscribing from all events
