- Getting started
- Administration
- RPA workflow projects
- Creating an RPA workflow from an idea
- Creating a project
- How to start an RPA workflow
- Managing project files and folders
- Connecting RPA workflows to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- App projects
- Agentic processes
- Agents
- Solutions
- API workflows
- Tests
Solutions in Studio Web allow you to design and manage multiple automation projects and shared resources together within a single business process workspace.
The design time experience has evolved from working on a single, standalone automation to designing an entire business process. Instead of editing a single, isolated automation, you can now work on multiple automations and their associated resources within the same solution.
Working with solutions lets you:
- Define resources without leaving Studio Web.
- Design automations that reference defined resources before these resources are deployed in the UiPath platform. Automations interact with resource definitions in a contractual way, assuming that the resources exist with their specified definitions.
Each solution consists of one or several projects which can be managed from the Solution Explorer.
The Solution Explorer
The Solution Explorer helps you manage the projects in your solution, as well as the project files in each project.
From the
Solution Explorer button on the upper-left side of the designer, you can:
Use the
Add to solution button to add a project to your solution (Agentic process, Agent, RPA Workflow, etc.). -
Use the
Search button to find specific projects, files, pages, actions, variables, or arguments in your solution. -
Move files and folders by dragging and dropping them in the desired location.
Open the context menu for the solution to access more options:
- Add project to solution - Add a new project to the solution.
- Import existing (for cloud solutions) - Add an existing project to a solution saved in the cloud workspace. Inside the Add folder window, choose the projects that you want to import, and then select the Add button.
- Add existing project (for local solutions) - Add an existing project to a solution saved in the local workspace. Use the folder picker to select the project folder. If the selected folder is outside the solution folder, your browser asks you for read and write permissions to access it. The selected folder must contain a
.uiprojfile to be recognized as a project folder. If a project with the same name already exists, Studio Web automatically renames the new project by appending an incremental suffix (for example,ProjectName (1)). - Exclude project (for local solutions) - Remove a project from a solution. The project folder and all its contents remain on disk and can be re-added to the solution at any time.
- Open in Studio Desktop - Open the solution in Studio Desktop.
- Rename - Rename the solution.
- Properties - Open the Properties panel. Here you can update the solution's name and description.
Open the context menu for a project to access project-specific options.
Note:Windows projects are marked with a Desktop label and can only be edited in Studio.
A solution can be edited by multiple users simultaneously. However, only one user can work on a project at a time. Projects that are opened in another browser tab or by another user are marked with a lock icon in the Solution Explorer.
Project errors are visible to all users working on the same solution and are marked with an error icon in the Solution Explorer.
You cannot rename a project while another user is working on a project within the same solution.
The Resource Explorer
Resources added to your solution appear in a separate Resource Explorer, located at the bottom of the Solution Explorer. The Resource Explorer can be collapsed, expanded, or resized based on your needs.
Resources are automatically added to the solution as they are used by activities. Resources are grouped under these categories:
- Apps - User interfaces powered by automations that allow you to build custom business applications which connect to data.
- Assets - Shared variables or credentials that you can use in different automation projects.
- Business rules - Objects used to store and manage Decision Model and Notation (DMN) files.
- Connections - Integration Service connections that help in establishing tasks between single users and external applications.
- Context - Context Grounding indexes that give access to permissioned knowledge bases.
- Processes - Package versions linked to a particular folder.
- Queues - Containers that enable you to hold an unlimited number of items.
- Storage buckets - Per-folder storage solutions leveraged in creating automation projects.
- Task catalogs - Action containers where you can categorize your actions based on various criteria. The catalog that stores an action is set when an action is created, using action creation activities in Studio Web.
- Dependencies - Activity categories contextually linked into a specific project.
To upload a custom activity category:
- Open the context menu for the Dependencies node.
- Select Upload new packages.
- Choose your custom activity category. Supported file formats include .zip and .nupkg.
- Select Open. Your new activity category is added to the solutions and appears under the Dependencies node.
To change the version of an activity category:
- Expand the Dependencies drop-down menu.
- Open the context menu for an activity category.
- Select Change dependency version.
- Choose a version from the drop-down menu.
- Select Confirm version selection. Your project reloads. The new version then appears next to the category name in the Resource Explorer.
You can remove a resource by opening the context menu for it and selecting Remove from solution.
For more information on how to create, define, and use resources, refer to Solution resources.
To learn more about solution-aware activities that leverage solution resources, refer to the System activity package, the Persistence activity package, and the Integration Service user guide.
The Data Manager
The Data Manager lets you manage the data when working on an RPA workflow project that is part of your solution. This data includes:
- Variables - Store data and pass it between activities in a project.
- Arguments - Store data and pass it into or out of a project.
- Entities - Data Service records.
To learn more about the Data Manager, refer to Managing the data in a project.
The Issues panel
The Issues panel, also known as the Health Analyzer panel, lets you identify issues in the current project. To access the panel, select the
icon on the upper-left side of the page. The number of identified issues is displayed next to the icon.
Use the Show flat list and Show grouped list buttons at the top to switch between how items are displayed in the panel. The Filter button lets you filter items by scope, severity, or quality area.
Each entry in the Issues section features an icon indicating the severity level and a description of the issue. Expand an issue and select the project file where the issue occurs to navigate to the activity or element that triggered it.
The Toolbox
The Toolbox
is visible in the context of working on an app project. From the Toolbox, you can add or search for app controls.
The Deployment configuration panel
The Deployment configuration panel displays the components of the solution package. To access the Deployment configuration panel, select the
You can change how the components are listed from the View as list and View as tree buttons. You can also use the Search button to find specific components.
Selecting a component lets you review its properties. From the Display option, you can switch between viewing recommended properties or all properties.
The Notifications panel
The Notifications panel lists cross-tenant notifications related to actions performed in the context of your solution. To access the Notifications panel, select the bell
icon from the top navigation bar.
Notifications can be filtered by the services they reference or by their severity.
To learn more, refer to Notifications in the Automation Suite admin guide.
