studio-web
Studio Web user guide
- Getting started
- Administration
- RPA workflow projects
- Creating an RPA workflow from an idea
- Creating a project
- How to start an RPA workflow
- Managing project files and folders
- Connecting RPA workflows to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- App projects
- Agentic processes
- Agents
- Solutions
- API workflows
- Tests
Creating an agentic project
Create an agentic project in Studio Web by selecting Agentic Process from the Create New menu, which opens the agentic process designer canvas.
To create an agentic project:
- Go to the Workspace page in Studio Web.
- On the upper-right side of the page, select Create New.
- Select Agentic Process. A new solution opens, with the Agentic Process designer canvas displayed.
Alternatively, you can select the arrow next to the Create New button, and then choose Agentic Process from the list of available project types.
Each agentic project consists of one or multiple agentic processes.
From the
Project Explorer button on the upper-left side of the designer, you can:
- Use the
Add button to add a new agentic process to your project or import an existing agentic process. You can import .bpmn files created with any BPMN 2.0-compatible tools. - Use the
Search button to find specific project files. - Manage your project files. Right-click the top-level project to add an agentic process, import a .bpmn file, or rename, debug, or debug step-by-step your entire project. Right-click an individual agentic process (denoted by its .bpmn suffix) to rename, delete, or download the process file.
