- Getting started
- Administration
- RPA workflow projects
- Creating an RPA workflow from an idea
- Creating a project
- How to start an RPA workflow
- Managing project files and folders
- Connecting RPA workflows to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- App projects
- Agentic processes
- Agents
- Solutions
- API workflows
- Tests
Opening a project in Studio Desktop
Cross-platform project compatibility between Studio Web and Studio Desktop, including how to open Studio Web projects in Studio or StudioX on Automation Suite.
You have the option to work on your cross-platform projects in both Studio Web and in the desktop version of Studio. Studio Web projects are compatible with the latest version of the Enterprise and Community editions of Studio and can be opened in both Studio and StudioX. See Managing files in projects edited with Studio Desktop for restrictions on opening or editing projects.
You can either start from a Studio Web project and make it available in Studio, or start from a Studio project and save it to the cloud to make it available in Studio Web. When a project is available in both Studio and Studio Web, the changes you make in one platform are reflected in the other.
To open a project in Studio Desktop, from the Automations page in Studio Web, select See more
> Open in Studio Desktop on the right side of a project.
- If Studio is installed on your machine, select to open it when prompted by your browser. The project opens in a new instance of Studio.
- If Studio is not installed on your machine, click the link in the Open in Studio Desktop dialog to go to the Resource Center in Automation Cloud and download it.
You can also open a project in Studio Desktop from within a project when adding an activity that is only available in Studio Desktop. Once opened in Studio Desktop, the project is closed in Studio Web and you are redirected to the Automations page.
For more information about working on cloud projects in Studio Desktop, see the Studio guide.
