studio-web
Studio Web user guide
- Getting started
- Administration
- RPA workflow projects
- Creating an RPA workflow from an idea
- Creating a project
- How to start an RPA workflow
- Managing project files and folders
- Connecting RPA workflows to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- App projects
- Apps in Studio Web
- Designing app projects
- App templates
- Debugging app projects
- Publishing, deploying, and upgrading app projects
- Importing and exporting app projects
- Using a text prompt to generate an app
- Using a PDF or image to generate an app
- Generating VB expressions using a text prompt
- Working with entities in an app project
- Known limitations
- App activities
- Agentic processes
- Agents
- Solutions
- API workflows
- Tests
Generate VB expressions in Studio Web app controls using Autopilot text prompts, requiring sufficient Autopilot actions on the tenant before use.
Prerequisites
To generate VB expressions using text prompts, your tenant must have sufficient Autopilot actions available.
To generate VB expressions using a text prompt in Autopilot, follow these steps:
- Go to the app where you want to add a VB expression.
Note:
- Referring to all controls within a container by the name of the container is not supported. If an expression depends on multiple controls, the prompt must include every control name.
- Add a new control or select an existing control.
- In the Properties panel**,** select a condition where you wish to add the VB expression. Select the configuration button, then select Open expression editor. The expression editor opens.
When you write a text prompt describing the VB expression you want to add, Autopilot writes the generated VB expression and makes it available for use in the Expression editor text field.
Examples of Autopilot text prompts for VB expressions
Here are a few examples of useful prompts and their use cases.
| Apps controls | Intended functionality | Text prompt examples |
| Input controls | Disables a Submit button if a field is empty. | "If username and password are empty set to true" |
| App variables | Enables a button if an app variable called "item list" has a length greater than 10. | "If item list length is greater than 10" |
| Custom objects | Prints a personalized welcome message. | "Concatenate "Welcome" with current user displayname and email id" |
| Media | Renders a media file you have added to the app. | Write the file name: "image_01" |
| Process | Completes a message with a value from a process. | "Concatenate user billing total amount" |
| Process and app variables (sorting and filtering) | Assigns a value from a process data table to an app variable data table. | "Sort process users.datatable by rating in descending order and filter where name contains john" |
| Custom function (string addition) | Adds a string to a list called "itemlist". | "Add firstname to itemlist" |
| Query parameters | Fetches runtime parameters given to the app in the form of a string. In this case, the time zone and region of a user. | "Concatenate apps timezone and region query parameters" |
