studio-web
Studio Web user guide
Publishing and deploying solutions
Publish and deploy a Studio Web solution as a ZIP package to Automation Suite, replacing individual NuGet package publishing for multi-project automations.
Publishing solutions​
Publishing a solution creates a solution package.
Before solutions in a unified developer experience, each project was individually published as a NuGet package. While NuGet packages continue to be the way to pack individual automations, the entire solution is packed in a ZIP file.
The solution package contains all the deployment configurations, as well as the corresponding NuGet packages pertaining to each automation project. The solution package is transferable across tenants and organizations.
To publish a solution:
  1. Select the Publish button at the top of the designer.
  2. In the Publish solution window, choose where to publish your solution: For me (in your personal workspace) or Shared (in an Orchestrator tenant feed).
  3. Under Change log, add an optional description for your solution.
  4. For solutions under the Shared tab,, specify a version.
  5. Select Publish. An icon next to the Publish button informs you if publishing was successful or failed.
Solutions are published differently depending on the location you have selected.
Publishing to an Orchestrator Tenant​
When you publish to an Orchestrator tenant, a validation message appears in your solution designer once the solution package is created. A notification also appears in the Notifications panel.
To check the published solution package, select the Check package link in the validation message. You are then directed to the Tenant > Solutions > Packages > Package Versions page in Orchestrator.
For the developed automations to become executable, the solution package needs to be deployed. An Orchestrator Tenant enables other users to access your solution.
Publishing to a Personal Workspace​
The Personal Workspace is dedicated for your own usage. When you publish to your Personal Workspace, a validation message appears in your solution designer once the solution package is created. For convenience, publishing a solution to your Personal Workspace automatically performs a deployment, to bring the automation to an executable state.
To check the published and deployed solution package, select the Check Automation link in the validation message. You are then directed to the My Workspace > Solutions > Deployments > Deployment Summary page in Orchestrator.
Publishing individual projects from a solution​
In addition to publishing a full solution, you can publish individual RPA workflow or App projects from within a solution. This lets you update a single project's NuGet package without republishing the entire solution.
To publish an individual project from a solution:
  1. In the solution, open the context menu for the project you want to publish.
  2. Select Publish project.
  3. Complete the publish flow. The options and behavior match those of publishing a standalone project.
Result​
The project is published as a NuGet package using its existing publish bindings.
Publishing test cases from a solution​
You can publish test cases for an RPA workflow project that is part of a solution. This option is available in both Cloud Workspace and Local Workspace solutions.
To publish test cases from a solution:
  1. In the solution, open the context menu for the RPA workflow project that contains the test cases.
  2. Select Publish Test Cases.
Note:
The Publish Test Cases option is available only for RPA workflow projects that contain test cases.
Result​
The test cases are published as a NuGet package. The behavior matches publishing test cases in Studio Desktop.
Deploying solutions​
Once published, a solution becomes available for deployment anywhere within the tenant. The solution package can be found in Orchestrator, at the tenant level, under the Solutions tab. You can then initiate the deployment process from this location.
The solution generates all required artifacts in the folder that you have selected. During deployment, you can choose to use already existing resources instead of creating new ones (for example, you can use an already available asset instead of creating a new one).
Note:
Solutions published to a Personal Workspace are automatically deployed during publishing.
After a solution has been deployed for the first time, you need to follow the upgrade flow to deploy a new version of the solution, unless the goal is to deploy the solution in a different folder.
To move a solution package from one tenant to another, you need to manually download the package and uploaded it to the desired tenant.
Solutions are deployed as a whole. To minimize the manual tasks performed during deployment, reduce potential errors, and facilitate the development process, you can set the deployment configuration of a solution at design time.
This can be done from the Deployment configuration panel, where everything that will be deployed is listed along its respective configuration.
To learn more about deploying a solution published to an Orchestrator Tenant, refer to Deploying a solution in the Solutions Management user guide.
You can also deploy a solution for debugging purposes by:
  1. Navigating to the toolbar above the Studio Web designer.
  2. Selecting the Expand icon arrow next to the debugging environment.
  3. Selecting Deploy solution for testing from the drop-down menu.
Connect
Stay updated
