studio-web
Studio Web user guide
- Getting started
- Administration
- RPA workflow projects
- Creating an RPA workflow from an idea
- Creating a project
- How to start an RPA workflow
- Managing project files and folders
- Connecting RPA workflows to your accounts
- Configuring activities
- Managing the activities in a project
- Passing values between activities
- Iterating through items
- Managing the data in a project
- Configuring a project to use your data
- Using file and folder resources
- App projects
- Agentic processes
- Agents
- About agents
- Building an agent in Studio Web
- Solutions
- API workflows
- Tests
Agent building in Studio Web, and where the Agents user guide documents the designer canvas, the agent components, and each stage of the agent lifecycle.
Studio Web is the low-code design surface for UiPath® Agents. You create an agent project inside a solution, design it on the Agents designer canvas, then test, publish, and run it.
Agent building is documented end to end in the Agents user guide, which is the source of truth for the designer canvas, agent components, and the agent lifecycle. This page points you to the relevant sections.
Continue in the Agents guide
- Building an agent in Studio Web – Create the agent project, explore the designer canvas and its panels, choose between the Form and Canvas design modes, and configure the model, prompts, tools, contexts, and escalations.
- Testing the agent – Debug the agent in design time, evaluate its output, and calculate the Agent score.
- Evaluations – Measure agent output against expected results.
- Publishing and deploying the agent – Publish the agent to Orchestrator as a process.
- Running the agent – Run the agent as an Orchestrator job or use it in a Studio workflow.
- Best practices – Design reliable, production-grade agents.
