test-manager
2022.4
Solución de problemas
No se pudo iniciar la ejecución automatizada porque el paquete no se encontró en Orchestrator​
Mensaje de error
Automated execution could not start since the package was not found on Orchestrator. Only test cases from packages which have been published to Orchestrator can be executed.
Solución
Para solucionar este problema, asegúrese de haber habilitado.
Los casos de prueba no se podían ejecutar ya que no se podían encontrar versiones ejecutables​
Mensaje de error
Test cases could not be executed since no executable versions could be found. Only test cases published with the latest package version to Orchestrator can be executed.
Solución
This issue can also be triggered by a test case from your project that is linked to a different Test Manager project. To sort this issue, unlink the automation in Test Manager.
¿Necesita ayuda? Soporte
