Última actualización 13 de oct. de 2025
2023.10.4-patch 3
Release date: October 13, 2025
Corrección de errores
Fixed an issue that could cause the Automation Hub landing page to intermittently fail to load due to unhandled user validation errors.
For details regarding this patch, refer to Automation Suite on EKS/AKS or Automation Suite on Linux.
Note: The fixes included in this patch will also be part of all future releases starting with Automation Suite 2023.10.12. We recommend you upgrade to Automation Suite 2023.10.12 to get this fix.
  • Corrección de errores
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
