  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Automation Suite API guide
Last updated Feb 28, 2026
Delete Users
Deletes multiple users from an organization, based on the users IDs.
API Endpoint
DELETE https://{yourDomain}/{organizationName}/identity_/api/User
Scopes
Requires the following scopes:
  • PM.User
  • PM.User.Write
Request Headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters
Path paramData typeDescription
partitionGlobalId (required)StringThe ID of the organization you want to retrieve the robot accounts for.
Request Body
The request body contains the list of user IDs you want to bulk delete from the organization.
  "partitionGlobalId": "string",
  "userIds": [
    "string"
  "userIds": [
    "string"
Responses
204 Success
The indicated robot accounts are deleted from the organization.
Example Request
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/{tenantName}/
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: magic-7
  • The users you want to delete have the following IDs:
    • Dolores Umbridge: dol-2908
    • Quirinus Quirrell: qui-2609
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/User' \
--data-raw '{
    "partitionGlobalId": "magic-7",
    "userIds": [
        "dol-2908", "qui-2609"
--data-raw '{
    "userIds": [
  • API Endpoint
  • Scopes
  • Request Headers
  • Path Parameters
  • Request Body
  • Responses
  • 204 Success
  • Example Request
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
