- Getting started
- Authentication
- Scopes and permissions
- Platform Management APIs
- Update User
- Delete Specific User
- Delete Users
Automation Suite API guide
Last updated Feb 24, 2026
Delete Users
Deletes multiple users from an organization, based on the users IDs.
API Endpoint
DELETE https://{yourDomain}/{organizationName}/identity_/api/User
Scopes
Requires the following scopes:
- PM.User
- PM.User.Write
Request Headers
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters
| Path param | Data type | Description |
partitionGlobalId (required) | String | The ID of the organization you want to retrieve the robot accounts for. |
Request Body
The request body contains the list of user IDs you want to bulk delete from the organization.
"partitionGlobalId": "string",
"userIds": [
"string"
"userIds": [
"string"
Responses
204 Success
The indicated robot accounts are deleted from the organization.
Example Request
Let's say you gathered all the information needed to build the API call.
- Your
{baseURL}is:https://{yourDomain}/{organizationName}/{tenantName}/ - Your
{access_token}is:1234(for length considerations). - The
{partitionGlobalId}is:magic-7 - The users you want to delete have the following IDs:
- Dolores Umbridge:
dol-2908 - Quirinus Quirrell:
qui-2609
- Dolores Umbridge:
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/User' \
--data-raw '{
"partitionGlobalId": "magic-7",
"userIds": [
"dol-2908", "qui-2609"
--data-raw '{
"userIds": [
