Automation Suite API guide
  • Getting started
    • About this guide
    • Available resources
    • API endpoint URL structure
    • Enumeration List
  • Authentication
  • Scopes and permissions
  • Platform Management APIs
Delete Users
Deletes multiple users from an organization, based on the users IDs.
API Endpoint​
DELETE https://{yourDomain}/{organizationName}/identity_/api/User
Scopes​
Requires the following scopes:
  • PM.User
  • PM.User.Write
Request Headers​
Note:
To obtain the {access_token}, make sure to authenticate through one of the methods described here.
Path Parameters​
Path paramData typeDescription
partitionGlobalId
(required)
StringThe ID of the organization you want to retrieve the robot accounts for.
Request Body​
The request body contains the list of user IDs you want to bulk delete from the organization.
  "partitionGlobalId": "string",
  "userIds": [
    "string"
  "userIds": [
    "string"
Responses​
204 Success​
The indicated robot accounts are deleted from the organization.
Example Request​
Let's say you gathered all the information needed to build the API call.
  • Your {baseURL} is: https://{yourDomain}/{organizationName}/{tenantName}/
  • Your {access_token} is: 1234 (for length considerations).
  • The {partitionGlobalId} is: magic-7
  • The users you want to delete have the following IDs:
    • Dolores Umbridge: dol-2908
    • Quirinus Quirrell: qui-2609
The call should resemble the following example (cURL):
curl --location --request DELETE 'https://{yourDomain}/{organizationName}/{tenantName}/identity_/api/User' \
--data-raw '{
    "partitionGlobalId": "magic-7",
    "userIds": [
        "dol-2908", "qui-2609"
--data-raw '{
    "userIds": [
  • API Endpoint​
  • Scopes​
  • Request Headers​
  • Path Parameters​
  • Request Body​
  • Responses​
  • 204 Success​
  • Example Request​
Connect
Stay updated
