Automation Suite admin guide
Last updated Apr 23, 2026
Managing system administrators
System administrators, also known as host administrators, have the required privileges to configure all host-level settings, which apply for all your organizations and tenants.
First system administrator
After completing the installation, the admin user account is automatically provisioned which has system administrator privileges.
Where can I get the credentials?
The details for the first system administrator account, called admin, are available in the cluster_config.json file.
You can use this account to log in to the host portal. If needed, with this account you can create additional system administrator accounts.
Adding a system administrator
  1. Log in to the host organization with a system administrator account.
  2. In the Accounts and Groups section, select Add User in the top right of the page.
    The Add User panel opens from the right of the window.
  3. Fill in the fields with the details for the new system administrator account:
    • If the new account will use their username and password (basic authentication) to log in, fill in the password for the account. The system administrator may be required to reset their password on first login, depending on your security settings.
    • If the new account will log in with Google or Microsoft Entra ID, you must fill in the email and it should match the one tied to their account in the external provider.
    • For a new log in via SAML, the fields will match the selected SAML user mapping. If the user mapping is set to by user email, then the email must be filled in. If the user mapping is set to by username, then the username must match the username in the SAML identity provider.
    • For a new log in via Windows Authentication (Active Directory), the username must be of the form user@domain - for example, john.doe@uipath.
  4. Select Save to create the account and close the panel.
    The new account is now displayed in the users list.
    An email notification is sent to the provided email address if notifications have been configured. Depending on your security settings, the new system administrator may be required to confirm their email address.
  5. If you configured the system administrator to use basic authentication, then provide the username (or email address) and password you provided for the account to the new system administrator so that they can log in.
    If you configured a system administrator to use an external identity provider then ask them to sign in to the host portal using the option for the respective provider.
Editing account details
As a system administrator, you can change the details of another system administrator account, including the account password.
To edit account details of an existing system administrator account:
  1. Log in to the host portal with a system administrator account. The host portal opens.
  2. Select Users. The Users page opens displaying the list of system administrators.
  3. Select the Edit icon at the right end of the account row. The Edit User panel opens from the right of the window.
  4. Edit the information as needed.
  5. Select Save to apply your changes and close the panel.
Deleting system administrator accounts
As a system administrator, you can delete system administrator accounts to prohibit a user from accessing the host portals.
Note:
You cannot delete your own account. You also cannot delete the last system administrator account. This is to prevent getting locked out of the host portals.
To remove a system administrator account:
  3. Select the Delete icon at the right end of the account row.
  4. In the confirmation dialog, select Delete to confirm the action.
The account is removed from the users list and can no longer log in to the host portal.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
