Automation Suite admin guide
- Getting started
- Host administration
- Organizations
- Authentication and security
- Licensing
- Tenants and services
- Accounts and roles
- External applications
- Testing in your organization
- Notifications
- Logging
- Troubleshooting
Application testing
Configure and use application testing capabilities across design, evaluation, and deployment stages in Automation Suite.
The application testing capabilities of the UiPath platform support all stages of the testing process, from the design of test automations to their evaluation and deployment.
- Designing test automations: You can design test automations through various methods within Studio. These include data-driven testing, supported by features like Data Service entities, test data files, test data queues, and auto-generated data. Test automations can be designed using either low-code automations, providing ease of use, or fully coded automations for those looking for a more customized experience.
- Activities in Studio test automations: Studio test automations offer robust activities for verifying assertions for your test cases, verifying documents or text equivalence, and generating random data. The activities that the Testing and Mobile Automation activity packages offer enhance the scope and reliability of your tests.
- UI testing: With the help of UI Automation, you can test UI elements efficiently. The feature leverages an object repository to streamline the process and ensure accuracy.
- Deployment of test automation projects: After designing and verifying your test automations, you can easily deploy these as packages to Orchestrator, enabling a smooth transition from test design to test execution.
- Test Manager integration: Test Manager serves as your hub for overseeing all the tests created and deployed through the Studio. It allows you to create requirements, test cases, test sets, and inspect executions. It also supports integration with a range of ALM tools through both out-of-the-box integrations and primarily Test Manager Connect. To get started with Test Manager, check out the available quickstart guide for Test Manager.
- Other services in the UiPath platform: In addition to these features, the UiPath platform includes other services to support your testing journey. These enhancements make test creation, execution, and evaluation an integrated and streamlined process, reinforcing the quality and performance of your applications.
