Automation Suite admin guide
About tenants
Tenants in Automation Suite: how they model organization structure and separate business flows across user groups.
Tenants allow you to model your organization structure, separating your business flows and information just like in real-life organizations. They are containers where you can organize your services and manage them for a group of users. For example, you can create tenants for each of your departments and decide what services you want to enable for each, based on their needs. In each tenant, you can have one instance of each of the cloud services.
Default tenant​
When you get started with an organization, your first tenant, called DefaultTenant, is automatically created.
Multitenancy​
Important:
For organizations that already have multiple Orchestrator services prior to launching the Tenants feature, a tenant is automatically created for each existing Orchestrator service, incorporating that service, with the tenant name inherited from the Orchestrator service.
Note:
All the data is stored in the cloud, in a database shared between only your tenants.
Users invited to an organization can only view tenants and services based on their permissions in various services. For more information, refer to Managing tenant and service visibility.
Orchestrator in your organization​
All Automation Suite tenants contain an Orchestrator service.
While in on-premises Orchestrator, your Orchestrator instance can include several tenants, in Automation Suite you have one Orchestrator service in each Automation Suite tenant.
An Automation Suite tenant is different from an Orchestrator tenant.
The following table describes the differences between an Automation Suite tenant and an on-premises Orchestrator tenant.
Tenant in Automation SuiteTenant in on-premises Orchestrator
Is a subdivision of the Automation Suite organizationIs a subdivision of the Orchestrator instance
Includes one Orchestrator serviceIs a part of Orchestrator
Includes several other cloud services (UiPath® products), all within Automation SuiteIs not in the same medium as your other UiPath products and interacts with them through integrations
Note:
For more information about the differences between on-premises Orchestrator and the Orchestrator service in Automation Suite, also refer to Orchestrator differences .
Viewing tenants​
Organization administrators can view and manage all of the tenants in their organization.
All existing tenants are displayed on the Admin page, in the panel on the left:
Tenant statuses​
Tenants can be in one of two states:
  • Enabled - the tenant is active and can be accessed by users.
  • Disabled - the tenant is not active and unavailable to users. Disabled is shown next to the tenant name in the tenants panel:
Switching tenants​
If your organization has multiple tenants and you have access to more than one, you can switch between tenants while on the page of a tenant-specific service. This lets you work with the data that exists within the selected tenant for the various services, which can be different than what is available in other tenants, or your service-level roles can be different between tenants.
To switch the context in which you are working to a different tenant, select the tenant list in the top right and select another tenant:
The page refreshes and then shows data for the newly selected tenant.
  • Default tenant​
  • Multitenancy​
  • Orchestrator in your organization​
  • Viewing tenants​
  • Tenant statuses​
  • Switching tenants​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
