Studio
Banner background image
Studio User Guide
Last updated May 13, 2024
Extension for Edge
Important: UiPath® Inc. and its affiliates, do not process, use, access, or store any customer data when using this product.
Important:
The deprecation of Manifest V2 extensions is scheduled to begin in June 2024.
Enterprises using the ExtensionManifestV2Availability policy to ensure the continued functioning of Manifest V2 extensions in their organization will have one additional year – until June 2025 – to migrate the Manifest V2 extensions in their organization. Browsers with the policy enabled will not be impacted by the rollout of the deprecation until that time.
The UiPath Extension for Edge MV2 installed by older versions of UiPathStudio.msi will stop working in Edge. We highly recommend upgrading your UiPath Studio and Robot installations before this happens.
See the full timeline for the Edge migration to MV3 extensions here.
The UiPath Extension for Edge MV3 is available starting with the following UiPathStudio.msi versions:
  • 2022.10
  • 2022.4.4+
  • 2021.10.8+
  • 2020.10.14+
  • 2019.10.9+
These can be downloaded from the Resource Center of UiPath Automation Cloud.
This extension helps you create browser automations in Microsoft Edge. You can install this extension in multiple ways, as shown below:
Install from UiPath Studio
  1. Open Studio.
  2. Navigate to Home > Tools > UiPath Extensions.
  3. Select Edge > Install. Choose one of the available methods from the drop-down:
    • Group Policy Offline
    • Group Policy Online
    • All Users
    • Current User
    • Native Host Only
  4. Open Edge and navigate to edge://extensions.
  5. Enable the UiPath Web Automation extension if needed.
Install from the Studio installer
  1. Run the UiPathStudio.msi installer.
  2. Select an install mode, and then select Advanced Settings > Extensions > UiPath extension for Edge Chromium. If Edge is installed on your machine, the option is selected by default.
  3. Click Install. Studio setup continues while also installing the extension for Edge.
The UiPath Extension for Edge can also be installed from the command line of UiPathStudio.msi.
Install from Group Policy
You can also install the UiPath Extension for Edge by using Group Policies. This method silently installs the extension and enables it, without requiring user confirmation.
Offline
This installation method requires that the target machine is joined to a Microsoft Active Directory domain or Azure Active Directory.
It does not require access to the Edge Web Store so it can be used in controlled environments for machines that have restricted Internet access.
UiPathStudio.msi uses this installation method by default if its requirements are met.
You can also use this installation method by running from an elevated command prompt:
&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-policy-offline /silent&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-policy-offline /silent
If your organization uses Group Policies for browser extension management then the following changes are also required:
  1. In the ExtensionInstallForcelist policy, add the value:
    ndmegdjihnhfmljjoaiimbipfhodnbgf;file:///C:/ProgramData/UiPath/UiPath.Common/EdgeExtension_SelfHosted/extension_manifest_edge.xml
  2. In the NativeMessagingAllowlist policy add the value:
    com.uipath.chromenativemsg_v2
  3. Set DeveloperToolsAvailability Group Policy to the value 1 (Allow usage of the Developer Tools) to enable the full extension functionality. For more information, please check the troubleshooting page.
If you need to host the UiPath extension in your internal Web Store you can find the .crx file at this location:
C:\Program Files\UiPath\Studio\UiPath\BrowserExtension\uipath_extension_for_edge_self_hosted_mv3.crx
Online
This installation method requires that the target machine has access to the Edge Web Store (https://edge.microsoft.com/extensionwebstorebase/v1/crx and https://msedgeextensions.sf.tlu.dl.delivery.mp.microsoft.com).
UiPathStudio.msi uses this installation method if its requirements are met and the machine is not joined to a Microsoft Active Directory.
&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-chromium-policyglobal /silent&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-chromium-policyglobal /silent
    aolkfhjgbinoablafekggeglohbacjih;https://edge.microsoft.com/extensionwebstorebase/v1/crx
  2. In the NativeMessagingAllowlist policy, add the value:
Uninstalling
The UiPath Extension for Edge can be uninstalled by running from an elevated command prompt:
&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-chromium-cleanup /silent&"C:\Program Files\UiPath\Studio\UiPath\SetupExtensions.exe" /edge-chromium-cleanup /silent
You can also uninstall by opening Studio, navigating to Tools > UiPath Extensions, and selecting Edge > Uninstall. The extension will be uninstalled with the same method used for the installation. This method is displayed in the disabled drop-down next to the Uninstall button.
Edge version requirements
The UiPath Extension for Edge MV2 works with all existing Edge versions.
The UiPath Extension for Edge MV3 requires Edge version 98 or greater.
When using one of the installation methods described above, the browser version will be checked and the extension with the appropriate format (MV2 or MV3) will be automatically installed.
New extension features
Support for IE Mode
Starting with UiPathStudio.msi 2020.10 the UiPath Extension For Edge can be used to automate web pages running in Internet Explorer mode.
Web pages containing Java Applets, Silverlight and ActiveX controls can be automated in Internet Explorer mode.
Automating Edge apps
Starting with UiPathStudio.msi 2022.4 the UiPath Extension for Edge can be used to automate Edge Apps.
Troubleshooting
Your system administrator might have configured Group Policies that prevent the UiPath® Extension for Edge from working. To enable it, please follow the instructions from the Group Policies page.
For any other issues regarding the UiPath Extension for Edge, please view the detailed troubleshooting page.
