Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Invoking Code Source File
- Using Coded automation in Low-Code workflow
- Integrating Low-Code workflow in Coded automation
- Invoking Coded automation in another Coded automation
- Integrating OpenAI with Coded Workflows
- Apply for a loan with UiBank
- Queue generation with coded workflows and Orchestrator APIs
- Using imported library projects in coded automations
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- About extensions
- SetupExtensions tool
- UiPath.UIAutomation.Activities packages and UiPath Remote Runtime versions mismatch
- Screen resolution settings
- Chrome Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Edge Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
Studio User Guide
Last updated May 13, 2024
In this tutorial, you can learn how to incorporate a
low-code workflow inside a coded automation. This example is similar to the Using Coded automation in Low-Code workflow tutorial, but the
other way around. The tutorial shows how to invoke the
ResetAssetValue.xaml
low-code workflow into the
CodedAutomationUsingWorkflow.cs
coded automation.
The
workflow performs the following steps:
- Retrieves the current value of a specific asset from Orchestrator.
- Compares the retrieved asset value with the input value provided as an argument.
- If the previous asset value does not match the input value, it updates the asset value in Orchestrator.
- Logs messages that indicate the status of the asset value, whether it was updated or remained unchanged.
