Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Introduction
- Registering custom services
- Before and After contexts
- Invoking Code Source File
- Using Coded automation in Low-Code workflow
- Integrating Low-Code workflow in Coded automation
- Invoking Coded automation in another Coded automation
- Integrating OpenAI with Coded Workflows
- Apply for a loan with UiBank
- Queue generation with coded workflows and Orchestrator APIs
- Using imported library projects in coded automations
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- About extensions
- SetupExtensions tool
- UiPath.UIAutomation.Activities packages and UiPath Remote Runtime versions mismatch
- Screen resolution settings
- Chrome Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Edge Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
automation
Studio User Guide
Last updated May 13, 2024
This tutorial shows you how to invoke a coded automation
within another coded automation. We demonstrate this by using a sample scenario where a
coded workflow invokes the
CodedResetAssetValue
coded automation. The
automation retrieves the values of an asset,
compares them to an input value, and updates the asset in Orchestrator if the values are
different. If the values are the same, it logs a message that the asset value remains
unchanged.
