Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- About extensions
- SetupExtensions tool
- How to configure a multi-hop connection
- UiPath.UIAutomation.Activities packages and UiPath Remote Runtime versions mismatch
- Screen resolution settings
- Chrome Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Edge Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
Studio User Guide
Last updated May 13, 2024
To reach a destination remote computer via multiple connections, you must install Remote Runtime on each intermediary remote computer, not only on the final target computer.
Consider the following scenario:
- Machine A (with Studio and/or Robot) connects via RDP (Microsoft Remote Desktop Protocol) to Machine B, and
- Machine B connects via RDP to Machine C, where the target application is running, and the automation must be performed.
In this example, the following configuration is required:
- Machine A ā install Studio/Robot and the Extension for Microsoft Remote Desktop and Apps (UiPathĀ® RDP extension).
- Machine B ā install the
Extension for Microsoft Remote Desktop and Apps and
UiPathRemoteRuntime.msi
. - Machine C ā install
If other types of connections are used between two machines, you must configure a
connection at each hop, with the appropriate extension:
- Extension for Citrix for the case of Citrix connection
- Extension for Microsoft Remote Desktop and Apps (UiPath RDP extension) for the case of RDP connection
- Extension for VMWare Horizon for the case of VMWare connection
Let's consider another scenario in which:
- Machine A (with Studio and/or Robot) connects via RDP to Machine B, and
- Machine B connects via Citrix to Machine C, where the target application is running, and the automation must be performed.
On Machine B (or other intermediary machines), you can install the extension with one
of these methods:
- Run the
installer and select from the Product Features list the required extension. Refer to Installing the UiPath Remote Runtime - From the Installer. - From Command Prompt run
SetupExtensions.exe
(located in the folderC:\Program Files (x86)\UiPath\RemoteRuntime
) with the parameter corresponding to the required extension:
Regardless of your multi-hop connection scenario, if you are automating a Java
application or a web application, you must also install the corresponding extension
(the extension for Java, Chrome, Microsoft Edge, Firefox) on the remote machine.
This can be done by running:
- the
installer, as described in Installing the UiPath Remote Runtime, or - the
SetupExtensions.exe
tool located in the installation folder of UiPath Remote Runtime (default%ProgramFiles(x86)\UiPath\RemoteRuntime
), as described in About the SetupExtensions tool.
