Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- About extensions
- SetupExtensions tool
- UiPath.UIAutomation.Activities packages and UiPath Remote Runtime versions mismatch
- Screen resolution settings
- Chrome Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Edge Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
The required UiPath extension is not installed on the remote machine
Studio User Guide
Last updated May 13, 2024
You are automating a Java application or a web application and the corresponding extension (the extension for Java, Chrome, Microsoft Edge, Firefox) is not installed on the remote machine.
The error message indicates that you need to install/enable the associated UiPath Extension on the remote machine.
Install the required extension on the remote machine by using one of the following options:
- Run the
UiPathRemoteRuntime.msi
installer, as described here in Installing the UiPath Remote Runtime. - Run the
SetupExtensions.exe
tool located in the installation folder of UiPath Remote Runtime (default%ProgramFiles(x86)\UiPath\RemoteRuntime
), as described in SetupExtensions tool.
