Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- About extensions
- SetupExtensions tool
- UiPath.UIAutomation.Activities packages and UiPath Remote Runtime versions mismatch
- Screen resolution settings
- Chrome Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Edge Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
Check if ComSpec variable is defined correctly
Studio User Guide
Last updated May 13, 2024
The
ChromeNativeMessaging.exe
process runs under the current user
and it uses cmd.exe
to start the browser.
If the
ComSpec
environment variable is missing or has an invalid
value, then Microsoft Edge cannot launch the
Furthermore, the administrator may disable the command prompt for some users or configure it to always run with elevated privileges.
Manually add the correct value for the
ComSpec
environment variable.
This variable is set at Windows installation and must be set to:
%SystemRoot%\system32\cmd.exe
If the
ComSpec
environment variable is set correctly but the problem
persists, the user may not have permission to run the command prompt. In this case,
the ChromeNativeMessaging.exe
process cannot be started with
cmd.exe
running under the current user.
Starting with Chromium 120.0.6090+, a
NativeHostsExecutablesLaunchDirectly
Group Policy allows admins to turn this on for users in
restricted environments (Cloud PCs that forbid cmd.exe
, for
example).
