Studio
- Release Notes
- Getting Started
- Setup and Configuration
- Automation Projects
- Dependencies
- Types of Workflows
- File Comparison
- Automation Best Practices
- Source Control Integration
- Debugging
- The Diagnostic Tool
- Workflow Analyzer
- About Workflow Analyzer
- ST-DBP-023 - Empty Workflow
- ST-USG-032 - Required Tags
- Variables
- Arguments
- Imported Namespaces
- Coded automations
- Recording
- UI Elements
- Control Flow
- Selectors
- Object Repository
- Data Scraping
- Image and Text Automation
- Automating Citrix Technologies
- RDP Automation
- Salesforce Automation
- SAP Automation
- VMware Horizon Automation
- Logging
- The WebDriver Protocol
- Test Suite - Studio
- Extensions
- About extensions
- SetupExtensions tool
- UiPath.UIAutomation.Activities packages and UiPath Remote Runtime versions mismatch
- Screen resolution settings
- Chrome Group Policies
- Multiple browser profiles
- Group Policy conflict
- Chrome Extension on Mac
- Edge Group Policies
- List of extensions for Edge
- SAP Solution Manager plugin
- Excel Add-in
- Troubleshooting
Check if ChromeNativeMessaging.exe is running
Studio User Guide
Last updated May 13, 2024
The
enables communication between the UiPath Extension for Edge and the UiPath Studio/Robot.
- Open Microsoft Edge.
- Open Task Manager.
- Check if the
process is running. -
If the process is not running:
